More ignitor questions
this thread has 2 replies and has been viewed 1051 times
Old 04-21-2005, 10:24:40 AM
Ken Adamson Ken Adamson is offline
Default More ignitor questions
My FM Z 3 HP gear driven Sumter mag ignitor was put together improperly.
Yesterday when reading one of Elden DuRand’s post/replies about ignitors, it dawned on me that my ignitor was not set up properly (hum-maybe that is why it wont run). After doing a little research, Elden’s site and reading some of Elden’s work it was very obvious that when I put the ignitor back together I didn’t get it right (thanks for the info Elden).
Now for the question; is there a diagram some place to look at and get directions from so that this poor old ignitor can finally be put together correctly?
Thank you
Ken
Old 04-22-2005, 04:56:34 AM
DanR
Default Re: More ignitor questions
I have the same engine with the same problem (maybe). Let me know what you find out if I miss it. The mag may have been tweeked by my helper.
Best regards, DanR
Old 04-22-2005, 10:31:18 AM
Elden DuRand's Avatar
Images: 6
Ken & Dan:
Low tension ignition is not very complicated once you understand the underlying principles. Actually, for low-speed engines, it is very reliable.
You can look here at Harry's for explanations of the various kinds of ignition systems used by the makers of our old engines:
http://www.old-engine.com/magneto.htm
There are also a lot more interesting facts and interesting stuff at:
http://www.smokstak.com/links/browselinks.php?c=10
If you still have questions, let me know here and either me or someone else here will try to answer them.
I've done a study of the Webster low-tension ignition system on my web page. You can access it directly by going to:
http://home.cybertron.com/~edurand/A...0pictures.html
Good luck!
Take care - Elden
Ignitor What Does This Fit? Lauren Antique Gas Engine Discussion 2 12-06-2007 01:19:40 AM
Ignitor Joe Morris Antique Gas Engine Discussion 0 11-12-2007 05:48:47 PM
More Ignitor/mag questions Jebaroni Antique Gas Engine Discussion 6 05-29-2005 11:37:30 PM
Ignitor ID Jason Dahm Antique Engine Archives 3 04-03-2003 12:50:11 AM
Ignitor LOREN W. Antique Engine Archives 1 07-26-2001 10:15:32 PM
