Leak between tank and carb
this thread has 5 replies and has been viewed 1048 times
Old 04-21-2005, 10:26:53 PM
ldj1002 ldj1002 is offline
Default Leak between tank and carb
This isn't an old engine but it has me stumped and maybe someone has an idea for fix.
This thing is leaking between the carb. and gas tank. I made 2 new gaskets and put permatex on one, both leaked. Never made a gasket that didn't work but I went and bought a new gasket and it also leaked just like the ones I made.
I have put a lots of these tanks and carbs together and never had one leak, not even a little.
Any ideas what to try next?
L.D.
Old 04-21-2005, 10:39:54 PM
Default Re: Leak between tank and carb
Could it be that it's leaking through the screw threads holding the gas tank to the carb? I'd try using the blue Locktite on the threads and see if that helps. If that doesn't cure it, would look for a hairline crack in the carb body or possibility the carb is getting too much fuel and leaking out the choke or throttle shaft, making it look like it's leaking at the gasket??
Bill
Old 04-21-2005, 10:56:44 PM
BobRR BobRR is offline
I agree with Bill is it possisable that the float level is to high, sticking or sank? BobRR
Old 04-21-2005, 11:43:00 PM
Email NOT Working
I'm not sure of your situation, but I think the other guys are onto something. If you have been successful various times until now, there is a variable somewhere that you have not isolated. I think the high float level/thread leak sounds pretty reasonable. Kevin
Old 04-22-2005, 08:53:34 AM
Partsman Partsman is offline
Card Sponsor
If the carb is bolted to the tank I have found a gas cap not venting will cause your problem. The pressure builds up and forces the gas out.
Old 04-22-2005, 07:55:10 PM
Thanks all,
The problem was the diaphragm cover. It was't flat, causing it not to make a good seal on the rubber. I got a file and worked it down flat. It doesn't leak now. Sure thought it was that tank gasket first. The bottom of that rascal is right a the bottom of the carb. right where that tank gasket goes.
Stover CT3 Oil Leak Greg-N-CA Antique Gas Engine Discussion 12 09-13-2005 09:10:54 AM
oil leak Jesse Zilafro Antique Engine Archives 1 10-09-2004 08:52:46 AM
JD LUC compression leak. John Bailey Antique Engine Archives 7 04-01-2003 12:08:16 AM
Briggs Model U with Under Carb Gas Tank Mike in NC Antique Engine Archives 3 03-01-2003 05:21:41 PM
NO leak JD 1 1/2 HOW randy Antique Engine Archives 11 06-14-2001 01:45:01 AM
