2 HP IHC Pump engine gas tank repaired.
this thread has 5 replies and has been viewed 1246 times
Old 04-23-2005, 04:09:10 PM
Images: 17
Cool 2 HP IHC Pump engine gas tank repaired.
Thought I would pull the gas tank on my IHC pumper project. Good thing I did, as it had a few holes in the bottom of the 20" x 7" x 5" tank made of 1/8" plate. S'oooo I got the sawzall out, cut off 6", cleaned out all the old "CRUD" soldered up a couple of new pin holes I created and welded it back together. I now have a non leaking 14" x 7" x 5" tank. As soon as it dries inside, I'll give it a couple coats of tank sealer. Just having fun, on a dreary day, with the weekend off, even in NJ.
Check out the Pump engine project page at ;
http://www.Geocities websites CLOSED in 2009/oldengineon...umpengine.html
Did you make a new friend today, and a lot. Paul - "OLDIHC"
Old 04-24-2005, 12:24:38 AM
David Nicolson David Nicolson is offline
Default Re: 2 HP IHC Pump engine gas tank repaired.
Hi Paul, about to start on my 2hp inter vertical are the measurements of the fuel tank that size originally. Mine has the large base that would have had a pump mounted on it. Dave in Oz
Old 04-24-2005, 07:15:32 AM
Images: 17
David: The pumper engine base gas tank is part # G1478 which is a 5 gallon tank. I'm sure mine was a replacement at some point based on the way it was made(all welded seams), and was around 2-1/2 gallons. The length and width fit nicely in the base with plenty of room left for height so it could be made up to hold 5 gallons with no problem. For ocassional use at shows, mine will work just fine.
Old 04-24-2005, 07:03:49 PM
Hi Paul, i was thinking of making a smaller tank for mine as i doubt anyone would need more than a gallon or two for a rally. Are the pump outfits scarce in the states i havn't seen another one out here.
Old 04-25-2005, 04:02:53 AM
Images: 17
David: I would say that they are quite uncommon. I know of 3 including mine in my "small" knowledge base. Probably a few more, but no one else is coming to the table . Put in the first coat of tank sealer, but it leaked out . That is, it leaked out of the return line hole I didn't have taped up good enough . Later this morning I'll put in a second coat before mounting the tank back under the base.
Old 04-25-2005, 04:08:46 AM
Images: 17
Already did it.
1919 Z with repaired flywheel 1911_75_CASE Antique Gas Engine Discussion 7 08-22-2007 12:10:48 AM
IHC. Famous Engine. Should it be a Screen or Tank Cooled ? Uncle Old Iron Antique Gas Engine Discussion 6 06-19-2007 11:13:01 AM
Ebay find,Monitor Pump Jack engine complete with pump and arms Benny Mckheean eBayŠ Auction Discussion 1 09-02-2005 06:27:14 PM
Cart for a 4 hp IHC Tank Cooled Engine? Pat Heider Antique Engine Archives 1 04-19-2004 08:31:09 PM
