Polished Flywheels
Other than the usual, what have you fellow engine collectors used to polish the face of the...
this thread has 18 replies and has been viewed 2419 times
Old 04-27-2005, 06:07 PM
Keith Smigle's Avatar
Keith Smigle Keith Smigle is offline
Default Polished Flywheels
Other than the usual, what have you fellow engine collectors used to polish the face of the flywheels on your engines? I have heard angle grinder, emery cloth, sand paper and even a red brick Just fishing for ideas.
~Keith
Associated Mfrs Web Site
Old 04-27-2005, 07:07 PM
Dale S Dale S is offline
Smile Re: Polished Flywheels
Keith,
On my engines I used different grits of emery cloth and a block of wood while I had the engine running.This worked very well for me.
Old 04-27-2005, 08:06 PM
Bob Johnson Bob Johnson is offline
Default Re: Polished Flywheels
I have access to volcanic cinder rocks that are very abrasive, just hold the stones to the flywheel as the engine runs .
Bob, Out west on the high desert
Old 04-27-2005, 08:16 PM
Bob, "volcanic cinder rock" would be like the pumice stone that people use for landscaping and false charcoal briquettes in their gas grills wouldn't it?
The same soft stuff that's in lava hand cleaner right? Kevin
Old 04-27-2005, 08:52 PM
Tim Christoff Tim Christoff is offline
The mesh type sheetrock sandpaper works very well to bring back a quick shine after a winter in storage.
Tim Christoff
Old 04-27-2005, 09:48 PM
mowerguy
Exclamation Re: Polished Flywheels
Just A word of caution keep one thing in mind what ever you use.
All that abrasive grit has to go some whare, hopefully not in your gears or cylinder. (or lungs)
Old 04-27-2005, 09:52 PM
Unregistered
belt sander with the engine running
Old 04-27-2005, 10:01 PM
Allen Lapage Allen Lapage is offline
Just keep one thing in mind all that abrasive grit is going to land some where. Hopefully not in your gears or cylinder.
Old 04-27-2005, 10:58 PM
Orrin Orrin is offline
Scotchbrite pads.
I put some oil on the flywheel, first, so if there is any loose grit generated it stays put on the pad.
Orrin
Old 04-27-2005, 11:25 PM
Originally Posted by Orrin
Scotchbrite pads.
Orrin
Orrin
I do the same. No dust or rust particles anywhere.
Jim
Old 04-28-2005, 12:04 AM
Jim McCracken Jim McCracken is offline
I have used a handheld belt sander.First I get out my shop vac and place or duct tape the suction hose at about the 5 o'clock position.I then start the engine and hold my sander above the vac hose at about the 3 o'clock
position.seemed to work good.On a real rough wheel I start with coarser paper and progress down to very fine,then steel wool with WD-40 on the pad.
Old 04-28-2005, 01:39 AM
Images: 4
I have had good luck with the sponge sand pads that Harbor Freight Tools sells. I just run the engine and hold the sponge against the flywheel.
I don't use any oil but hold the sponge block at the back of the flywheels where centrifical force throws any grit away from any critical parts and the lack of oil assures that no grit will stick to the flywheel.
After I am done I spray a little WD-40 on to retard rust. Here in So. Cal. I am fortunate that the climate is such that everything is pretty easy to maintain.
If you had an extra rough flywheel you could rig up an arm that would hold the sanding sponge against the back of the flywheel and run the engine turning and replacing the sponge from time to time untill you achieved the desired effect.
Dick
Old 04-28-2005, 06:24 PM
This photo is what made me think of asking how other people polish 'em up. Check out that Associated line up! That is how Associated flywheels came from the factory.
~Keith
Old 04-28-2005, 11:31 PM
hitmis1 hitmis1 is offline
Hi Keith, I have 5 original Associated engines and none of them show any sign of highly polished fly wheels. They still have the uniform tool marks on the wheels. Do you think they were highly polished.
Bill In KY
Old 04-28-2005, 11:54 PM
BobRR BobRR is offline
Keith I have to ask where was that pict. taken?BobRR
Bill~
I don't think they were highly polished, but certainly bare metal. Any one with an Associated engine with an all original factory finish should be able to attest that the flywheel face and machined edges are bare unpainted metal. That is how my 1911 Hired Man is, the red paint on the flywheels stops at the edge of the machined surface at the flywheel edge. Also these Associated engines were painted with a brush after assembled and test run. The photo is in Great Britian. There are many surviving examples of Assocaited engines there. They were sold along side with CASE tractors and impliments.
~Keith
Old 04-29-2005, 12:26 AM
yes the volcanic rock is like pumice, looks like foamed rock the same as you see in charcoal cookers.
Old 07-20-2005, 12:56 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
I'll just add my two cents in here as well. I have seen people (when it is feasible) take an engine and start it running. Then take a strip of canvas belting like would normally go on the pulley and wrap it around the edge of the flywheel and somehow fasten it so that the belt is stationary and the pulley just spins inside of it. You could just nail the ends of the belt to a heavy board and get some pretty good tension. Just let the engine sit and run (also good for simulating a light load) and the rubbing action of the belt on the surface will do a nice gentle polishing/brightening of the faces. Cheap, easy, no muss, no fuss. I have also seen this done where the engine to be polished was not running but the belt was hooked up to an engine that WAS running so the running engine was spinning the belt and the flywheels were stationary as an alternate way of doing this. Seemed to be a good idea to me.
Jeb
Old 07-20-2005, 01:35 PM
boblester40 boblester40 is offline
i find a vibrating sander with a medium grit works well, it brungs up the wheel with out loosing the origanal maching marks etc.
Different Flywheels Gerry Boose Antique Gas Engine Discussion 5 07-07-2007 09:21 AM
Flywheels Ihorse Antique Gas Engine Discussion 2 09-21-2005 10:07 PM
Polished brass:To coat or not to coat? Lou Quirch Antique Gas Engine Discussion 5 01-03-2005 08:11 PM
Flywheels Chris Ocwieja Antique Engine Archives 4 10-27-2000 10:18 PM
JD 1 1/2 Flywheels Jim Pennycuff Antique Engine Archives 3 03-06-2000 01:34 AM
