fairbanks morse garden tractor
Last winter, I started to build a 2hp throttle governed FMZ garden tractor. (I don't want this to...
this thread has 6 replies and has been viewed 1660 times
Old 04-28-2005, 02:42 AM
CGBusch CGBusch is offline
Default fairbanks morse garden tractor progress
Last winter, I started to build a 2hp throttle governed FMZ garden tractor. (I don't want this to be a butt-buggy, but rather a true working tractor.) The frame is homemade and is constructed with a large variety of parts. It runs, drives, stops. I had a problem though, the floatless carb/mixer would starve on hills.
This is the carb bowl I made out of the IH 20-40? brass carb bowl. This will bolt beneath the mixer on the frame. I tested it with water and it works. I'll make new gaskets and will test it with rubbing alcohol (since its less viscous).
The tank on the side is a hill climbing anti-starve tank, since the gas tank behind the crank guard its still possible to starve the carb on extremely steep inclines. The outlet is mounted flush, while the inlet is a longer nipple that goes halfway into the can so the inlet is effectively in the middle.
I noticed however with my testing the mini tank only partially fills. Since there isn't an air gulp the mini-tank won't fill all the way? Will it eventually fill?
If it eventually fills, will there be a siphon effect even though the input is at the top?
Do I need to install a air gulp check valve? Would a check valve just leak?
Should just I install a 2ndary line from the top of the mini-tank to the top of the main tank? I think that would fix it...
Chris
Old 04-28-2005, 09:32 AM
Harvey Teal Harvey Teal is offline
Default Re: fairbanks morse garden tractor progress
Chris, the engine should produce enough suction to pull the fuel directly from a small tank located near the mixer, if appropriate check valves are used and the packing gland around the mixture screw is tight. Why are you placing the fuel tank behind the engine?
Old 04-28-2005, 10:34 AM
I want it to look good too. I have an old McCormic Deering secondary gas tank (6in by 12 in cylinder fuel tank) and it looks best mounting behind the crank and 10in above the original ground level of the engine. The original tank was below the engine and would starve going up hills and required the mixer to be adjusted when the tank ran low (which the original users must have had to monkey with too).
Old 04-28-2005, 10:50 AM
So you're doing gravity feed?
Old 04-28-2005, 11:39 AM
Elden DuRand's Avatar
Images: 6
What I did with my ZC-52 engine on my Hoyt-Clagwell butt-buggy (AND working tractor) was to put a stiffer spring (about twice as stiff - "guess, cut and try" mode was used in the selection) in the inlet air choke plate. This gives more suction to draw fuel from the tank mounted beneath the engine.
I went one step further. I tapped the hole in the cast iron plate 1/4-20 where the original choke spring rod was removed. I made new spring rod from 1/4" bar stock and threaded the inside (throttle plate) end about two turns and jammed a nut on it to hold the spring. I then threaded the outside end of the rod long enough to screw into the choke plate with generous room for a lock nut. I slotted the outside end of the rod for a screwdriver. Now I can adjust the tension on the choke spring.
It's a balancing act between the needle valve and the choke tension. The needle valve adjusts the high speed (power) mixture and the choke spring tension adjusts the idle mixture. It takes a bit of juggling to make it work right but, once done, it requires very little twiddling with the needle between full and nearly empty tank and moderate hills are not a problem. (my tank is a little over 4" deep with the feed from a 2" deeper "well" in the center.
That's my experience, consult your doctor or take two aspirin and call me in the morning.
Take care - Elden
http://home.cybertron.com/~edurand
Old 04-28-2005, 11:04 PM
Yep, I'm doing gravity feed.
Old 05-01-2005, 02:41 AM
Default engine stopped running (garden tractor)
I installed my IH carb bowl beneath the mixer of my FMZ on my garden tractor. At first it didn't work. I took it apart again and I think the float was stuck. I tested and retested and everything looked good. I drove it over to get water and went to the garden to pull a cultivator. I was pulling it ez in the plowing gear (a very low gear on my peerless trans), I ran to get weight and noticed the engine quit... Is it out of gas? nope. go to restart it, where's the intake valve?
The valve keeper clip must of busted! It sucked in the valve and bent it. The head and looks like they only got a minor nick, so I'll order new parts and hope to get working with it again. I plan on installing a sleeve hitch, then the tractor will be very useful.
garden tractor Jerry Scholton Garden Tractors / Mowers / Scooters 1 07-02-2007 01:14 PM
Garden Tractor ID Pete Wygant Garden Tractors / Mowers / Scooters 2 12-15-2006 09:05 PM
Help ID garden tractor ldj1002 Garden Tractors / Mowers / Scooters 1 06-12-2005 11:12 AM
Larger Fairbanks Morse tractor WOW Kelly Barnett Antique Tractors - Old Iron Lugs, Cleats and Tracks 0 11-29-2004 12:23 AM
red e garden tractor Tim Antique Engine Archives 10 08-14-2002 12:56 AM
