buzz coil/bosch
this thread has 9 replies and has been viewed 1432 times
Old 04-28-2005, 09:49:55 PM
ldj1002 ldj1002 is offline
Default buzz coil/bosch
I rigged up a buzz coil using a Bosch relay. Pretty sure I did it by instructions but it has a itty bitty puney spark which I'm sure won't run an engine. I know the coil is good because I've been running my Novo with it. Anyone had any luck with the home made buzz coil?
L.D.
Old 04-28-2005, 11:13:14 PM
oldironcollector's Avatar
oldironcollector oldironcollector is offline
Default Re: buzz coil/bosch
You have got something wrong some where, the ones I have assembled have an incredible spark . What you may have is a coil with a good primary winding (will run an ignitor engine) but a high resistance secondary winding. You see when running an ignitor engine you are only utilizing the primary circuit of the coil by flowing the electricity through the coil. Not using the coil for high voltage output from the secondary side of the windings. I would try another coil.
My 2 cents per gallon surcharge
Denny
Old 04-28-2005, 11:18:45 PM
Sorry I just read into your post a little deeper and I would imagine your Novo to be spark plug and high tension, I would double check all the connections to insure they are correct and make sure you have good voltage from the battery. I have always used 12 volt coils and 12 volt batteries I don't know how the Bosch relay will function at lower voltages as it was designed to operate at 12V.
2 more cents per gallon surcharge . man this stuff is getting expensive!!!
Denny
Old 04-29-2005, 12:42:53 PM
JBailey
Make sure that the relay you're using is a Single Pole Double Throw (SPDT) relay. I tried rigging up one with a Single Pole Single Throw (SPST) relay and it will not work. You can't tell the difference between the two just by looking at the case. You have to look at the schematic printed on the case. I have a NAPA part number at home if you have trouble finding the correct relay. You must hook up to the normally closed terminal 87a. Otherwise it won't work. I fought this same battle just this week. Mine now throws a good healthy spark.
John
Old 04-29-2005, 12:45:21 PM
JBailey
One other issue. I initially tried mine using a small trickle charger as a power source. It would not work. Had a really weak spark if any at all. But, when I tried it on a good healthy 12 volt battery, it really came to life.
John
Old 04-29-2005, 05:01:54 PM
BobRR BobRR is offline
What did these relays originally run on a car? Thanks Bob
Old 04-29-2005, 05:04:05 PM
Hank Czerwick Hank Czerwick is offline
I played and played with this, checked and double checked everything and couldn't get it to work. like you say nothing but a tiny spark. Finally rewired it not following the diagram but running the ignition coil in series with the coil on the bosch relay. As opposed to using the Normaly opened side of the relay to feed the ignition coil. The ignition coil that I was using was brand new from the parts store so I'm pretty sure it was a sound coil. Once I did this it worked great, so good it's almost scary and will toss a couple of inch long spark if hooked to a good battery. Have been using this for a couple of years now without any problems. Built a real nice little wooden box for it with some brass screws and knurled thumb screws for hook ups. Looks and works nice.
Hank
Old 04-29-2005, 09:34:47 PM
I got it working and it is wired as the instructions, auto coil parallel with coil in relay. I don't know why it didn't work at first. probably not good connections as I was twisting up temp wiring.
Old 04-29-2005, 10:11:38 PM
Bob,
The relays are used for many applications on cars on a Ford Crown Vic they are used as fuel pump relay, ac clutch relay, headlamp relay, abs relay, power window relay. I used to work for a county govt. and everytime a car was totaled we would scavange all of the relays off of it for later use. Man at the coffee cans full of them !!!! and probably would use one or two a year.
Denny
Old 04-29-2005, 11:08:12 PM
Thanks Denny Ford parts to boot!! BobRR
Why a buzz coil? Scheetz83 Antique Gas Engine Discussion 10 09-24-2007 04:11:15 AM
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 06:08:54 AM
buzz coil BobRR Antique Engine Archives 3 03-11-2003 10:12:00 PM
Buzz Coil Value Robert in W. Mi Antique Engine Archives 12 01-29-2003 01:19:55 PM
BUZZ COIL A.J. TELOWICZ Antique Engine Archives 5 01-16-2003 12:40:35 PM
