Fuel pump needed
I am looking for a plunger type fuel pump to adapt to a small verical hit & miss "T" head engine...
this thread has 3 replies and has been viewed 721 times
Old 12-26-2000, 08:16 PM
Jim Sherman
Default Fuel pump needed
I am looking for a plunger type fuel pump to adapt to a small verical hit & miss "T" head engine that I have (not a Fairbanks T). I don't care what the fuel pump came off from as long as I can make it work on the engine. There is a plunger rod that travels vertically 3/8" that is what will activate the pump.
Thanks, Jim
Old 12-26-2000, 10:54 PM
Default Re: Fuel pump needed
A fuel pump such as you require is not difficult to make. Take a look at the McCormick M engine pump. All they are is a plunger (solid shaft) passing through a gland with a packing device/guide operating in a cylinder with 2 check valves, 1 in the bottom of the cylinder (inlet) and the other on the outlet. The fit is not important as they operate on displacement only. With only 3/8" of stroke a rather large plunger (1" anyway) should be used or you'll get no volume.
Old 12-27-2000, 01:18 AM
paul woodworth
Dear Jim The response from Graig is right on the fuel pump . The IHC pumps are made that way. they are sized by H.P. the 1 1/2 is 3/8" dia Rod 3 H.P. is 7/16" & the 6 H.P. is 1/2" Dia. But the stroke is about 3/4"?. They Pump to a over flow carb. I have built this IHC pumps for about 30 years. Iron Man Paul
Old 12-28-2000, 09:49 PM
larry harding
if you don't care about looks an old automotive fuel pump can be rigged up, they don,t need very much travel to pump. i have seen some old engines that were done this way probably after the original pump gave out. a little neater way is to use pipe fittings, a tee with two check valves at the bottom of a nipple,then a solid rod that fits inside the nipple with out too much slop. a regular pipe cap can be drilled for the plunger rod and used for a packing gland. crude? yess but i made a water pump this way that worked great.
Fuel Pump help needed Kevin Weis Antique Gas Engine Discussion 3 03-13-2009 10:47 PM
Lister CD Fuel pump needed Shadow B Vintage Diesel Engines 4 02-10-2007 01:37 PM
Kohler 161 fuel pump needed Kenn K Garden Tractors / Mowers / Scooters 0 11-29-2006 01:33 PM
fuel Pump Identification Needed Martin Reed Antique Gas Engine Discussion 1 05-03-2006 05:31 PM
Mogul Fuel Pump Help Needed Dan Bogart Antique Engine Archives 2 05-21-2003 10:09 PM
