LB 3-5hp Rod Bearings
this thread has 5 replies and has been viewed 1384 times
Old 05-02-2005, 05:21:47 AM
Chuck Parcher (Ks.) Chuck Parcher (Ks.) is offline
Default LB 3-5hp Rod Bearings
Searched the archives, and vendors. Can't find anything on rod bearings for 3-5 hp LB's. Did they have replacable rod bearings, or ??????????
any info would be appretiated.
Thanks......CHUCK
Old 05-02-2005, 11:56:41 AM
Dave from Omemee Dave from Omemee is offline
Default Re: LB 3-5hp Rod Bearings
I made a set. Used copper pipe which I fit to the rod. Made a holder for the copper shells , tinned the inside of the shells with hard solder and then turned them down to fit the rod crank bearing. A bit of a messy job which involved alot of hand work and trial and error fitting but it can be done. Worked for me, engine runs fine.
thanks
dave from omemee
Old 05-02-2005, 09:12:51 PM
chuch woycke
I think Ed Deis of Hit&Miss in Orwell Ohio sells them. I bought a set for a 1 1/2-3 LB he advertised on Harry's site.
Old 05-02-2005, 09:50:10 PM
Chip Watford Chip Watford is offline
I made a bronze bearing for mine!Chip
Old 05-03-2005, 06:33:54 PM
KeithT KeithT is offline
I just bought a 3-5 and it had rod bearings in it, looked factory.I have a LA that doesnt have them. Thought they may have updated with the rod bearings and valve spring oiler wick in the 40's
Old 05-10-2005, 12:24:54 AM
OK....Here's what I did. First of all the only bearings I could find were for the 1 1/2 - 2 1/2............I had two rod bearings (4 Halfs) for a 302 Ford sitting on the shelf. They snapped right into the rod cap. They were about a 1/2 inch longer. I cut the halves to the right length, then I ground a relief in the cap and connecting rod for the tab that keeps the bearing from turning. I put 2 halves side by side, great fit with a little groove in between for oil. I silver soldered the ends together, made a wood fixture. I put the bearings in the fixture, turned them to the proper I.D. clearance. then I honned them real smooth. Put the rod and piston back in the engine, and torqed her down. GREAT FIT. Engine turns easy, and runs nice and quiet. Thanks for all the suggestions...........
CHUCK
Rod Bearings Mo 92 Frank Timmermeier Maytag Engine Collectibles 6 04-20-2008 12:00:59 AM
bearings Kyle McGee Antique Gas Engine Discussion 2 04-01-2006 07:34:53 PM
bearings BDMelon Antique Gas Engine Discussion 12 10-09-2005 10:19:58 AM
JD-E 1-1/2 Bearings Jim Tremble Antique Engine Archives 3 10-27-2003 11:16:21 AM
Bearings. CJ Winslow Antique Engine Archives 3 11-02-2002 12:25:57 AM
