IHC 6HP M Fuel lines
this thread has 3 replies and has been viewed 1438 times
Old 05-05-2005, 10:30:03 AM
RHudson RHudson is offline
Default IHC 6HP M Fuel lines
Might anyone have a good photo of how the fuel and water lines should be run on a 6 hp M?
Thanks fellows for helping me with my 3 M truck.
Old 05-05-2005, 12:05:19 PM
John Hammink's Avatar
John Hammink John Hammink is offline
Default Re: IHC 6HP M Fuel lines
At hundred pictures you see them all different in a certain way. I always use as example these views, but direct the discharge over the fuel fill pipe as can be seen in the picture. Hope it gives you any idea.
Old 05-05-2005, 04:44:15 PM
There is no water line on the 6 M. It feeds directly thru the mixer from the hopper. Most have a 1/4 line from the pump to the lower side of the mixer and a 3/8 line from the bottom of the mixer to the tee on the filler pipe. hope this wil help a little. Joe Morris
Old 05-06-2005, 05:41:04 AM
Exclamation Re: IHC 6HP M Fuel lines
The IHC M engines did not use copper on the fuel lines, although that is what everyone uses to replace them. The originals were made of brass!
IHC Type M fuel lines Tom S Antique Gas Engine Discussion 6 08-01-2007 12:14:05 PM
IHC M fuel lines Tom Martin Antique Gas Engine Discussion 9 02-05-2007 10:54:10 PM
IHC M Fuel lines Tom Martin Antique Gas Engine Discussion 17 01-17-2007 04:32:28 PM
Cleaning gunged up fuel lines Stans Antique Gas Engine Discussion 11 12-09-2006 09:31:29 PM
Sealing Fuel Lines Christopher Winslow Antique Engine Archives 1 02-20-2002 05:59:08 PM
