Headless Witte info needed
this thread has 6 replies and has been viewed 2108 times
Old 05-09-2005, 06:57:39 PM
David OBrien David OBrien is offline
Default Headless Witte info needed
I aquired a 6hp Headless Witte this weekend but need some close up pics or detailed info of the ignition setup as well as the fuel tank and lines. I have parts of the ignition still on this engine but feel that some of it is homemade and would like to see the original parts. I could also use some explanation as to the wireing. This was a mag equiped engine but I am going to set it up to run with battery and coil as I don't have a good mag. I would appreciate any and all info you can give. Thanks
Old 05-09-2005, 07:13:11 PM
Bill Decker's Avatar
Bill Decker Bill Decker is offline
Default Re: Headless Witte info needed
Go to the link below. There you will find some pics of my 6hp headless Witte. I don't have any pics of the ignition, but there are some of the gas tank and plumbing.
Headless Witte's
Old 05-09-2005, 07:28:22 PM
Nick's Avatar
Nick Nick is offline
Images: 41
Well here's one with a Bosch BAO mag.
And here's another with the Webster mag.
And here's yet another with battery ignition.
For battery ignition you will need the spark lever. I can get more pics in the morning if no else posts something.
Cheers NICK
Old 05-09-2005, 09:06:28 PM
This help any?
[IMG][/IMG]
Old 05-09-2005, 09:41:11 PM
Thanks, all this has been of great help but still dont have all I need. Bill could you send me a scan of just the right half of the page you posted. I need to blow it up to see it better but the writing is blurring by then and I cant read it.
Old 05-10-2005, 07:41:55 AM
Luke Tonneberger's Avatar
Luke Tonneberger Luke Tonneberger is offline
I just got my 6hp Witte running this past weekend after having it about 4 years and never doing anything with it. I planned on selling it at swap meet on Friday. I monkied with it on and off throughout the day and by the end of the day it was running. It ran so well I ended up removing the price and decided to keep it. It is missing the brass tag off the hopper. Does anybody know if the serial number is stamped somewhere else on the engine?
David, If you look at the picture that Bill Decker scanned, the right hand side has two pictures that shows the spark lever that you will need to run it off buzz coil and battery. If you don't have this part, you could still probably rig some type of wiper/timer that would work.
Luke Tonneberger
Rockford, MI
USA
Old 05-10-2005, 12:54:45 PM
Tony Leonard's Avatar
Tony Leonard Tony Leonard is offline
On Headless and "B" models, Witte stamped the serial number on the end of the crankshaft and on the outer rim of both flywheels. This makes it very easy to detect if the engine has the original crank and flywheels. Sometimes it is hard to read the serial numbers on the flywheels if they are heavily rusted or pitted.
Nick, do you still own that Headless Witte with the High Tension Webster magneto???
Tony Leonard
Rockwell, NC
FM 1.5hp Headless Emergency Info needed!!! M Schwab Antique Gas Engine Discussion 6 08-20-2007 05:14:20 PM
10 HP Witte Info Needed Tom G Antique Gas Engine Discussion 2 06-06-2007 11:36:21 PM
Jacobs/Witte Info Needed randymontana Generators & Motors General Discussion 2 02-12-2007 05:35:36 PM
Headless Witte Jerry willis Antique Engine Archives 6 05-26-2004 05:02:23 PM
Witte Kero water injection info needed Norm Antique Engine Archives 7 05-09-2001 11:50:23 PM
