Schmidts Chilled Cylinder - now crank case
this thread has 16 replies and has been viewed 2261 times
Old 05-16-2005, 11:14:08 PM
Ihorse Ihorse is offline
Default Schmidts Chilled cyl
I need to see how the fuel tank/system is on the 3hp Schmidts chilled cyl engine is arranged--please post a pic or send to me,
thanks d,j,
Old 05-17-2005, 02:52:01 PM
John Hammink's Avatar
John Hammink John Hammink is offline
Default Re: Schmidts Chilled cyl
d,j just fresh taken at our engine show last weekend, don't know more about it. Hope it helps you.
Old 05-17-2005, 05:23:25 PM
Mike's Avatar
Mike Mike is offline
Images: 1
I have a color picture from the catalog but it is too large a file to post here.
If you email me, I can email the scanned picture. The tank is a gravity fed system to the lunkenheimer updraft mixer. Tank is clamped on to the fuel/air mixure pipe. Mike
Old 05-17-2005, 05:54:00 PM
Thanks guys--as were at it--how does the con rod get oiled??? the crankshaft is not drilled--and it is a open crankcase--how the heck does it oil??
thanks d,j,
Old 05-17-2005, 08:23:34 PM
Peter Peter is offline
The cap on the end of the connecting rod has a little snout that scoops up oil while the engine is running. Like a splash; but more a scooping action. So; you need some oil in the sump. And there should be a drain plug.
Old 05-17-2005, 09:18:33 PM
I understand what you said--what I don't ubnderstand--how the hell do you keep out the dirt--it is a open crankcase????
any help here?
thanks d,j,
Old 05-17-2005, 10:03:04 PM
I guess its a rare odd-ball engine. If it was a good design there might be more made and more around. I guess. One thing for sure its no IHC. If I had to go back in time and buy and engine for real use, it sure not be this one. My choice would be IHC for nice running, good quality. Oh well, I'm getting dangerously close to a trivia topic.
Old 05-17-2005, 10:24:07 PM
Images: 311
I never thought to take side view photos, but here are a couple of Schmidt's on this page:
http://old-engine.com/llmn.htm
-- Harry Engines Videos Photos
Old 05-18-2005, 02:40:24 PM
Photo Open crankcase Schmidts
OK--I took a picture of the opening/s on the Schmidts Chilled cyl--how in the world does it NOT splash oil al over the place--if--the rod uses a dipper--if you left the crankcase cover off of any closed case engine--you would be very oily-i think--don;t seem reasonable to me. the case is open on both sides the same.
d,j,
Old 05-18-2005, 03:05:41 PM
David M. Lyon's Avatar
Images: 32
Default Re: Schmidts Chilled Cylinder - now crank case
On top of the oiling problems, the crankshafts on these engines were WAY too small in diameter for the total length of the shaft, and had a tendency to twist on the pulley side. Also the connecting rod is so short, the piston will scuff the cylinder on the load side..But they sure are fun to look at and play with!!
David M.
Old 05-18-2005, 09:15:00 PM
Dick-CT Dick-CT is offline
Smile Re: Schmidts Chilled Cylinder - now crank case
on my schmidt eng the wrist pin is oiled by the oiler in the side of the cyl.
the wrist pin is drilled thru and has a hole drilled in the bottom of the pin.
if you take the oiler off the cyl you will notice that the end of the wrist pin will appear in the pipe hole when your turning the eng over. also there is no sump on these engs for any oil. dick-ct
Old 05-19-2005, 12:54:20 AM
ErikG ErikG is offline
My Schmidts has a small grease cup on the conecting rod on the crank end.
Erik Grund
Old 05-19-2005, 01:14:03 AM
Mike's Avatar
Images: 1
My Schmidts has a grease cup on the top of the rod bearing cap for the rod bearing. The drawing in the owners manual shows the grease cup in this location.
Old 05-19-2005, 08:50:35 AM
Images: 32
Mine is on the bottom of the rod so you can reach from under and grease the journal before starting.
David M.
Old 05-20-2005, 11:43:55 PM
Someone sent me a drawing from a book about how things work??-the picture was so large that it locked up my computer--I had to have the ISP--delete it-so I could use my e-mail--and I did not get the name--I would like them to resend, smaller--640 by 480 is good--the other one was over 1000k-acc the isp-and I think davids engine has a greaser--on his rod--there is no room for a greaser on mine--you can just barely slide a finger bettween the rod [cap] and the bottom of the crankcase--about 1/2 inch clearance--no room for a greaser
thanks d,j,
Old 05-23-2005, 09:50:39 AM
Images: 32
I guess they changed the design at some point...(this one is #5618) I didn't know any of them had a sump...How in the world do you get to the rod bearing to adjust it?...Shore ain't much room in those side openings!
David M.
Old 05-23-2005, 11:14:50 AM
Angry Re: Schmidts Chilled Cylinder - now crank case
The only way I can get at the rod -is to pull the cylinder off!!!
what a snafu outfit,
d,j,
SchMidts Chilled Cyclinder 5HP Greg Doby Antique Engine Archives 0 02-27-2003 10:55:23 AM
SchMidts Chilled Cyclinder Hopper Cooled engine Greg Doby Antique Engine Archives 3 11-22-2001 07:32:07 PM
Schmidt's Chilled Cylinder Larry Kastens Antique Engine Archives 6 06-10-2001 10:53:39 PM
Schmidt Chilled Cylinder Dick Antique Engine Archives 1 09-24-2000 04:46:49 PM
SchMidts Bros Chilled Cylinder Greg Doby Antique Engine Archives 0 02-29-2000 09:48:13 PM
