Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
What is this whatits??
I uncovered this item from the back of the shop, where it has been for ???? years--I don;t have a...
this thread has 11 replies and has been viewed 2263 times
Old 05-20-2005, 10:32 PM
Ihorse Ihorse is offline
Photo What is this whatits??
I uncovered this item from the back of the shop, where it has been for ???? years--I don;t have a clue--other than some kind of oil gizmo--it is about a foot tall and 5-in around at the top--made by Leiman Bros-Newark NJ--cast into the side of the bottom--ANY IDEAS??--someone has been likely looking for one of these for a long time;
thanks d,j,
Old 05-20-2005, 11:43 PM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
Default Re: What is this whatits??
It looks like it could be some kind of a pump.Sight oilers would lube bearings.May be a small burner unit such as to melt solder or babbit. Dick in central Pa.
Old 05-21-2005, 12:56 AM
D.J. It's maddening to get my curiosity piqued and then not be able to pick the thing up and turn it over, studying every angle and detail. I haven't got a clue. I have seen some old lead furnaces and don't know why you'd need a belt drive for one. But I don't have a better idea, and there ARE a lot of things I have not yet seen! Kevin
Old 05-21-2005, 09:06 PM
Photo Re: What is this whatits??
Here is another picture--laying down--it is a oiler of some kind--that is a little belt driven pump--you see the drain valve in the pic---the two sight glasses-darned if I know-
d,j,
Old 05-21-2005, 11:14 PM
BillsToys BillsToys is offline
It appears to have a sight glass on a pressure side and one on the suction side? Is that a small arrow for direction of rotation above the pulley on your second picture?
Bill in Cleveland
Old 05-22-2005, 12:10 AM
Chuck Parcher (Ks.) Chuck Parcher (Ks.) is offline
I think these were used on portable steam, or wind operated sewing machines down around Saragosa.......
seriously I have no clue what it is. They sure did make a lot of stuff back in the old days. did'nt they?
Chuck
Old 05-22-2005, 01:08 PM
Yes--that is a directional arrow cast into the side of the pump- counterclockwise rotation,--curious enough , there is no bolt holes in the top flange--so no lid--no cover-just the oil was open to the elements??
d,j,
Old 05-22-2005, 02:57 PM
Guessing this item would have been used inside a building where it would be out of the elements. Anyone in Neward, NJ want to go down to the library and check for any records of Leiman Bros. and see if there's any mention of products they manufactured and when? I'd go myself but a little too far away.
Bill
Old 05-22-2005, 04:02 PM
handlebar99 handlebar99 is offline
No need to go to the library -- if you "Google" Leiman Bros. Newark -- I think you will come to the conclusion that the whatsis is some form of vacumn pump. (Ain't the internet grand?)
Ray Rice
Old 05-22-2005, 10:37 PM
Chip Watford Chip Watford is offline
I've got a flat belt driven bench grinder with "Leiman Bros Newark N.J." cast in the top. Chip
Old 05-23-2005, 11:37 PM
I think that a countercloskwise rotation would pump fluid into the bottom of the pot. There may have been a lid clamped on top of the pot. Is there ball checks in the top of the little sight glasses? And is the exit hole in the pot threaded?
Bill in Cleveland
Old 05-25-2005, 01:45 PM
Ned L Ned L is offline
I wonder if this is any relation to "Lehman" out of Newark NJ that was well known for it's marine conversion of engines (esp. Ford diesels)?
