IHC M Fuel pump question
this thread has 3 replies and has been viewed 1929 times
Old 05-22-2005, 10:52:57 AM
David OBrien David OBrien is offline
Question IHC M Fuel pump question
I have in all accounts a great running nearly original IHC McCormick Deering M 1.5hp. recently I got it out to start it and while priming the mixer the fuel tank began to overflow, whenever I start this engine I usually have to prime it. My original thought was that the check valve in the pump may be leaking by, and the privious primings just added too much extra fuel to the tank. I took the fuel line and check valve out to find that they were in good condition, this is a new pump but I reused the original fittings. My question is should there be a small spring on top of the pump check ball to help hold it in place? The ball I am speaking of is on the output line and this is an eared style pump. I found reference to a spring but this was on a button top pump and it looks slightly different then the eared design therefore I dont know if this applies to my pump or not. Your advise and help will be greatly appreciated. Thanks David
Old 05-22-2005, 12:36:45 PM
BobRR BobRR is offline
Default Re: IHC M Fuel pump question
No springs on the ck. balls.Sounds like you have one of those very rare engines that makes its own fuel!! The M's have a overflow carb everytime you fill the carb to start the extra fuel runs back to the tank by the return line.Run it for several hrs and this problem will go away.BobRR
Old 05-22-2005, 01:44:05 PM
John Hammink's Avatar
John Hammink John Hammink is offline
The new pumps have mostly a nipple at the charge side with an inbuilt ball and little spring to hold the ball in place. You say you reused the old one so I think you're missing this check valve. The only way the tank can overflow is when you first fill it to top and then fill the mixer with a greater amount than it can hold before draining it to the tank again.
Old 05-22-2005, 09:56:26 PM
Exclamation Re: IHC M Fuel pump question
1) do not overfill tank, as per earlier posts., 2) check vent on fuel tank, if it is blocked, the return fuel may blow back, 3) check your return pipe for blockage, and or debris, 4) make sure return from carb is working, by filling carb, and then opening drain valve. fuel should return to tank.
IHC 1-1/2HP M fuel pump question SteamCheng Antique Gas Engine Discussion 5 06-04-2007 08:28:53 AM
IHC leaky fuel pump question Fairbanks Kid Antique Gas Engine Discussion 8 02-11-2007 11:22:11 AM
Mogul fuel pump question Kevin Weis Antique Gas Engine Discussion 3 10-14-2006 07:33:02 PM
Rumely H Fuel Pump Cam Question?? Gasengin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 07-10-2006 09:24:33 PM
IH 3hp fuel pump question David McAdams Antique Engine Archives 4 12-05-2003 06:41:38 PM
