IHC M throttle shaft worn
this thread has 5 replies and has been viewed 2027 times
Old 05-24-2005, 10:46:39 PM
TomFG's Avatar
TomFG TomFG is offline
Default IHC M throttle shaft worn
My IHC M 1 1/2 hp has a very sloppy throttle shaft. The shaft
wobbles around in the bore too much, and will be sucking
too much air, if and when I ever get it running for the first time.
Any suggestions? I'm guessing my easiest course of action would
be to drill out the shaft bore, and put a bushing in it.
Might be a little tricky on the inner shaft bore hole though.
I don't think making an oversize throttle shaft would be too
easy, as the old brass shaft is pressed into the pot metal end.
I could see that breaking real easy.
How have any of you tackled sloppy throttle shafts on the M's?
Thanks, Tom
Old 05-24-2005, 11:53:50 PM
Junkologist's Avatar
Images: 129
Default Re: IHC M throttle shaft worn
I think what I would do, is get some epoxy like JB Weld and fill the throttle shaft holes with it and then drill them out to fit the throttle shaft. It would be hard to notice and I think it would last a good long time. I have fixed many carbs with sloppy throttle shafts this way.
Mike
Old 05-25-2005, 02:16:17 AM
John Hammink's Avatar
John Hammink John Hammink is offline
When it is worn out, I use a new trottle assy and drill the shaft hole out and place new made bushings with a press in fit and add a little loctite 270 at the od, it sits like a rock. The excess of the bushing inside the trottle plate hole, can be milled away like in the picture.This works great for me.
Old 05-25-2005, 09:44:24 AM
TomFG's Avatar
Thanks Mike and John for the great ideas. I was pondering bushings....but didn't even think about JB Weld. Thanks again for the help!
Old 05-26-2005, 01:01:02 AM
Exclamation Re: IHC M throttle shaft worn
The IHC M heads are dry heads - they get real hot, especially if you use Kerosene! JB Weld may not stand up to the wear and heat. Get a new throttle shaft from one of Harry's advertisers, and see how much slop you have with the new shaft - the originals are soft brass, and the head may not be worn badly. If the head is worn, have a shop install new bushings. If the shaft is not centered, when installed, the throttle will not close properly. Also, make sure to stake the screw for the throttle plate, so it can't work out, and drop the throttle plate.
Old 05-26-2005, 09:45:47 PM
Chip Watford Chip Watford is offline
Tom,I repaired the throttle shaft on my 6hp M as Mike said,with JB Weld and have had no problems.JB Weld is rated at 500 degrees and the shaft is in the gas and air stream which I figured should keep it cool enough.I filled the rear hole then stuck a 3/8 drill bit, shank first,into the epoxy.When it set up I twisted it out and had a perfect hole.I agree with Andrew and John,a bushing would be the best fix but your not doing anything that can't be undone should you decide. Chip
Converting A Vertical Shaft Lawnmower engine to a horizontal shaft Jordan Garden Tractors / Mowers / Scooters 18 06-16-2009 03:49:11 PM
Building up a worn shaft (spray welding) vicp Welding Shop 10 03-03-2009 09:33:51 AM
Cart-Wheel / Shaft, Fit / Tolerance, Worn Out? DerekC Antique Gas Engine Discussion 8 11-13-2007 04:41:04 PM
Farmall H gets frozen throttle shaft Norm S Antique Farm Tractors 5 01-24-2005 09:40:14 PM
throttle shaft extension Jerry Griffin Antique Engine Archives 4 03-14-2002 10:49:30 AM
