Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
unknown pump
Howdy gents, can anyone identify this pump? Is it a water or fuel pump? I have no idea what it will...
this thread has 4 replies and has been viewed 1207 times
Old 05-25-2005, 10:44 PM
David Greenwalt David Greenwalt is offline
Photo unknown pump
Howdy gents, can anyone identify this pump? Is it a water or fuel pump? I have no idea what it will work on, just picked it up 'cause the price was cheap and figured it would be good trading stock. Thanks, David.
Old 05-25-2005, 10:53 PM
Zira Zira is offline
Default Re: unknown pump
No, but I just (Monday) bought one identical to that but with a small accumulator & some kind of valve plumbed into it. I don't think they are real old (they use the modern stlye snap rings). I don't see where the intake is either. I can e-mail ou pics of what I got if you want.
Old 05-26-2005, 09:16 AM
Hi Zira, I didn't think it was real old, the price was too cheap. But it works good and would like to figure something to use it for. It had a small cast iron tank with it, I guess this is what you mean about the accumulator? It's a ball about the size of a tank float. What does it do? I figure if an engine needed a small pump this one would do until an original was found, so I reckon it will go on the shelf with my other "junk" until something comes up I can use it for. Never know. David.
Old 05-26-2005, 09:02 PM
Yes, that is what mine has too. I don't see where the intake is either, mine looks like it on has an out-go (or maybe only has an intake?). It was just small enough & cheap enough that I bought it on a whim. If you find out anything, let me know, & I will do likewise.
Old 05-26-2005, 09:48 PM
Scott's Avatar
Scott Scott is offline
It might be like the John Deere pto air pumps and there are holes drilled in the piston with a flat plate to act as a check valve to suck the air in around the rod. They are hard to see when they get covered with greese. An accumulator is like a shock absorber for the pump and piping.
Pump Jack pump cylinder? Jim Sherman Antique Gas Engine Discussion 0 05-23-2007 12:45 AM
Need help! Inverted pump. Any pump guys out here? Mike O Antique Gas Engine Discussion 14 01-30-2007 11:05 AM
Ebay find,Monitor Pump Jack engine complete with pump and arms Benny Mckheean Craigs List / eBayŠ Auction Discussion 1 09-02-2005 07:27 PM
unknown Tim Antique Engine Archives 2 01-27-2004 09:46 PM
