Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines
need help on Fairbanks Morse
Hi, I got this engine with a bunch of engines I bought and I would like some information on it. I...
this thread has 3 replies and has been viewed 1271 times
Old 05-27-2005, 12:13 AM
Kevin Roth Kevin Roth is offline
Default need help on Fairbanks Morse
Hi, I got this engine with a bunch of engines I bought and I would like some information on it. I couldn't find out anything about it in Wendel big yellow book. I would like to know what use it was made for and a ball park figure of what it is worth. It has an old restoration but has gotten tight again. I have it soaking with diesel fuel. Thanks Harry for the great sight and thanks for the help. Kevin
ID:	2163   Click image for larger version
Old 05-27-2005, 04:12 AM
Default Re: need help on Fairbanks Morse
Sweet looking engine! Value is a very tricky subject, isn't it? Kind of depends....
Check this out. There is a great section on carbs and mixers, and more. Look at the page on Air Friction carburetors. Your carb isn't identical, but shares quite a few features with the one featured. http://www.oldengine.org/members/allen/techindex.html
Old 05-27-2005, 08:25 AM
Doug Kimball's Avatar
Images: 62
I believe you have a Fairbanks-Morse marine engine, headless Type E. Made in singles rated 2 1/2 to 3 1/2 hp & twins of 5 to 7 hp. 7 hp specs: 3 3/4" stroke x 3 3/4" bore, 800 rpm. Weight about 203 lbs. Should have a brass 1" Schebler D updraft carb, most had a gear driven rotary water pump. Hit & Miss has a 4 page pamphlett & a little info in Wendel's 100 Years of Fairbanks Morse. I think these engines were manufactured in Toronto, Canada. In the condition it is in, value maybe $500; restored with correct parts & running $1500 ... just guesses on value.
Old 05-27-2005, 08:27 AM
Keith Smigle's Avatar
Keith Smigle Keith Smigle is offline
Kevin~
It is definitly a 2 cylinder marine engine used to drive a prop in a small boat.
~Keith
Associated Mfrs Web Site
Help with FAIRBANKS MORSE Mod. 32 JHFoster Vintage Diesel Engines 2 01-22-2006 06:36 PM
Fairbanks & Morse Gen. Set Heller D. Davis Generators & Motors General Discussion 1 09-11-2002 10:59 PM
Fairbanks-Morse John H Antique Engine Archives 2 11-04-2001 04:18 PM
HELP ON FAIRBANKS MORSE TOM BABYLON Antique Engine Archives 6 10-17-2001 07:47 PM
Fairbanks Morse ZC Tony Pitts Antique Engine Archives 3 09-30-2001 11:05 PM
