Got the N running!!
this thread has 2 replies and has been viewed 1335 times
Old 06-02-2005, 08:19:13 PM
Simple_serf Simple_serf is offline
Default Got the N running!!
After being on the back burner for 3 years, I finally decided to get my Briggs N off the shelf. It needed ca carb kit and I just didn't have the time to deal with it. Well, today I installed that kit, and another gasket for the mag plate end play and gave it a shot. After 3 years of sitting, it fired up first pull! Still has a problem with end play though. The mag plate is warped and if I am not careful with installing everything, the flywheel can rub the plate. This was the second engine that I painted up and tried to fix everything on when I first got started with these little engines. I also got my WM running (a liitle gas and an oil change) and I got the Novo running after fixing a little bearing problem. Still it's nice to get some stuff done in the shop. Now it's time to get ready for Coolspring...
The Simple Serf
Old 06-02-2005, 08:37:22 PM
Chris Kirk Chris Kirk is offline
Default Re: Got the N running!!
Serf -
Is that mag plate the same as a Briggs 5S or 6S? I have one of each, unwarped. If you want one, I'll send it to you for shipping.
Chris
Old 06-03-2005, 11:44:08 AM
I've got one from a WI that I might try. I also need to take a look at the con rod, because I think it may have something to do with that as well. Like I said, this was one of my fist, so there are a few things that I didn't check then that I do now.
The Simple Serf
The IHC M is running! Donald A Smith Antique Gas Engine Discussion 13 11-27-2007 09:18:29 PM
Got it running.......... Rich Martz Antique Gas Engine Discussion 4 11-04-2007 10:23:11 PM
Hot Running IHC 3 HP M Tom Graves Antique Engine Archives 8 03-30-2004 10:35:00 PM
6 HP Associated - Got it running! Paul Martin Antique Engine Archives 7 07-23-2003 02:59:41 PM
Running vs. non-running engines Chris Kirk Antique Engine Archives 19 12-22-2002 08:02:12 AM
