onan 6.5kw model 1a/1f ---i need help please
it looks like this thing has a water pump on the front is this a water cooled engine,,,it has 2...
this thread has 9 replies and has been viewed 2093 times
Old 06-02-2005, 10:50 PM
Randy S
Default onan mcck 1a/1f----i need help
it looks like this thing has a water pump on the front is this a water cooled engine,,,it has 2 hoses going to the heads
Old 06-02-2005, 11:23 PM
Randy S
Default onan 6.5kw model 1a/1f ---i need help please
i dont know much about these generators,the model is mcck1a/1f it looks like this thing has a water pump on the front of the engine is it possible its water cooled,,can some one tell me what i have thanks randy
Old 06-03-2005, 07:09 AM
Billy J Shafer's Avatar
Default Re: onan 6.5kw model 1a/1f ---i need help please
Randy You have a unit that came out of a boat.Yes it is water cooled,some units have two pumps.Will get back with you after work today.
Old 06-03-2005, 09:29 AM
Gunny Gunny is offline
Have seen folks use these to power up their house during a power outage. Use the swimming pool for cooling water. Guess you could also use a couple of 55 gallon drums. One thing to be careful of, if no heat exchanger, used water directly, the inside of the engine might not be in good condition. Water at 180 degrees is very corrosive to iron and steel and rots it away in very short order.
The pumps Bily mentioned are the weak point on those machines, find and keep on hand a couple of rebuild kits for them.
Good solid reliable machines, last a long time with some care. Heavy enough to be used as a second anchor.
Old 06-03-2005, 01:45 PM
Randy S
Default onan generator--i need info on it-any body please
i got this thing in A trade and i dont know anything about it,,,does anybody know anything about it,,,,,,model mcck1a/1f i have a lot of views and no response please help
Old 06-03-2005, 03:59 PM
Randy S
can a radaitor out of a car work for the cooling system
Old 06-03-2005, 06:09 PM
What all do you need to know.Water cooled unit,very heavy,very good unit.Water pump impellers are the weak point.Will run for ever if proper care taken.
Old 06-03-2005, 09:16 PM
Randy:
Yes.
Old 07-12-2005, 05:33 AM
DChrono1952 DChrono1952 is offline
Randy what you have is a Marine genset if you still have it I will like to hear from you. I need it for parts.
Danny!
Old 10-30-2007, 03:21 PM
kfrancis kfrancis is offline
I know of people who have removed the water pump completely and installed a 110v aquarium pump. It just needs to pump 3.5 gpm and they will run forever. I did it 2 years ago and haven't had a water problem since.
Onan model # 2.5LK-1R/6000 D OBrien Onan Generators 2 11-11-2007 10:42 AM
Onan 7.5jb manual and model - help JBittnerSr Onan Generators 1 08-26-2007 09:12 PM
Onan Model 5CS 500/w Dave Wright Onan Generators 3 08-04-2007 11:19 AM
Considering older Onan, which model? walexa07 Onan Generators 4 03-17-2007 10:49 AM
