i want to know what works good on repairing a hopper on witte water cooled engine
what works good to repair cracks on the hopper?? or what works good to cover grind marks??...
this thread has 5 replies and has been viewed 1159 times
Old 06-03-2005, 08:44 PM
MedicHamilton's Avatar
MedicHamilton MedicHamilton is offline
Smile i want to know what works good on repairing a hopper on witte water cooled engine
what works good to repair cracks on the hopper?? or what works good to cover grind marks?? thanks!!! god bless!!
Old 06-03-2005, 10:17 PM
Images: 4
Default Re: i want to know what works good on repairing a hopper on witte water cooled engine
I am a great believer in JB-Weld.
They make several products that will work well for your purpose.
Clean the surface and follow their directions.
I have only had one problem with JB-Weld and that is that It takes a long time to set and therefore requires the surface to be flat as it will run down hill slowly.
This problem can be overcome by either making sure the surface is level or by building some sort of dam to keep the weld where you want it untill it takes it's initial set.
I have used tape, wax and clay to build temporary dams to make it stay put during it's cure time.
If the cracks are wide enough that the weld will run thru the hole then I might use some of the metal repair clay type of product to stop up the hole initially. I'm sorry that I can't think of the name of that product but it comes in a clear plastic package and is about half the size of a cigar and has a 2 part composition the catalist being on the outside and the composite being on the inside.
Simply breake or cut off the required amount and knead it together and use a toothpick or something to plug up the bottom of the crack. Then use the JB-Weld to fill and seal the leaks.
More Free Advise.
Dick
Old 06-04-2005, 12:04 AM
Meco3hp's Avatar
Meco3hp Meco3hp is offline
Images: 62
Hello,
I've used the JB weld on rear ocasions where the crack is small and not seen very easily. I've also used it to "smooth" up a bad looking weld (spongy). I don't like the idea of messing with somebody elses repair as I don't know whats behind it.
Richard
Meco3hp's Avatar
Images: 62
Hello,
I've used the JB weld on rare ocasions where the crack is small and not seen very easily. I've also used it to "smooth" up a bad looking weld (spongy). I don't like the idea of messing with somebody elses repair as I don't know whats behind it.
Richard
Old 06-04-2005, 09:09 AM
Exclamation Re: i want to know what works good on repairing a hopper on witte water cooled engine
Dick, JB sets up fairly quickly, perhaps you had some old stock or didn't get the mix just right. I had some old stock JB and the set up time was nearly double the next batch I bought.
Old 06-04-2005, 09:50 AM
thanks everyone for the ideas i will use them!!!!!!!!! take care!!
Water Cooled Briggs Engine Jim Metzger Small Air Cooled Gasoline Engines 7 08-19-2007 11:41 PM
John Lauson 2 1/2 hp hopper cooled engine Serial # help. RIRR Antique Gas Engine Discussion 4 07-17-2007 10:35 PM
Ideal 4 hp. vertical hopper cooled engine John T. Antique Gas Engine Discussion 0 02-18-2007 01:46 PM
SchMidts Chilled Cyclinder Hopper Cooled engine Greg Doby Antique Engine Archives 3 11-22-2001 06:32 PM
Witte Engine Works KIM Generators & Motors General Discussion 2 02-15-2001 04:09 PM
