Info wanted on mechanical horse...
this thread has 8 replies and has been viewed 1619 times
Old 06-06-2005, 11:09:37 PM
Nate
Photo Info wanted on mechanical horse...
Anyone know anything about or where I can get info. on this mechanical horse... its run by a very early GE electric motor that says "alternating current" and looks like it is 20's or maybe earlier. The mechanisms are fitted with grease cups. I was thinking about changing it over to a hit and miss engine ..but I would like to know what I have before I mess with it...
Old 06-07-2005, 10:17:04 AM
BigJon BigJon is offline
Default Re: Info wanted on mechanical horse...
I believe I seen this horse (one like it) in the movie Titanic so that would date it pre 1912.
Old 06-07-2005, 11:18:55 AM
I that an early version of the kiddie ride outside 5 & 10 cent stores (giving away my age!!)?
Old 06-07-2005, 12:55:36 PM
Nate
I doubt that it was a kiddy ride..as the speed control is in front of/and controlled by the rider..and it is not coin-op....
Old 06-07-2005, 03:08:37 PM
I'd be leery of altering this in any way. You may have a very valuable item, though I know not a thing.
I do know that original is where the big value is usually is found. Besides, you could run it, as is, with electricity and that can be generated by a hit and miss engine.
While it would make quite an unusual display, it might be best to rope it off and only let experienced "cowpokes" ride it.
Recommended accessories for riding: Health and liabilty insurance, a saddle and a chunk of foam rubber!
Old 06-07-2005, 05:08:03 PM
Scott's Avatar
Scott Scott is offline
I thought I was the only one who caught that hit miss engine in the exercise room in the Titanic movie. Any other info on the electric motor? Volts etc. 32volt, ?
Old 06-07-2005, 10:30:04 PM
Exclamation Re: Info wanted on mechanical horse...
Chances are that the motor is 110 - 115, seeing as it's labeled alternating current. my guess is early 1900s. If you rig to a H&M engine, how will you regulate speed? Cool piece!
Old 06-07-2005, 11:59:36 PM
Nate
It is 110...played a little today and everthing is free even the motor...so it will be restored to original..
Old 06-08-2005, 01:11:25 PM
Robt.'s Avatar
Robt. Robt. is offline
Just don't try riding it without a saddle unless you have no further use for your .....
Seriously, as others have said, if value concerns you or you may want to sell it at some point, it is probably best left as is unless you can restore it to absolutely original specs.
IHC 1 1/2 horse need info tim w Antique Gas Engine Discussion 9 10-24-2007 01:04:05 AM
Info Request on a Wheel Horse 502 Tractor Doug Hanneman Garden Tractors / Mowers / Scooters 2 04-30-2006 06:21:44 PM
Leader Iron Works 1 1/2 horse info needed Dave Beck Antique Gas Engine Discussion 6 03-02-2006 09:38:41 AM
5 horse Sattley (field bundage?) any info on this engine? Dave Beck Antique Gas Engine Discussion 1 08-14-2005 10:38:58 PM
