tecumseh engine kicks back when starting.
i bought a tecumseh h-60 6hp that i put on my model 656 wheel horse. the problem is that when i...
this thread has 3 replies and has been viewed 3717 times
Old 06-07-2005, 11:14 PM
Ken Ken is offline
Default tecumseh engine kicks back when starting.
i bought a tecumseh h-60 6hp that i put on my model 656 wheel horse. the problem is that when i start it up it kick back on me and just about pull my arm out of the socket. it starts fairly easy but gets hot pretty quick then dies. would it be out of timming and how would i go about getting it back in time. any help or suggestions would be great. ken
Old 06-08-2005, 12:26 AM
Exclamation Re: tecumseh engine kicks back when starting.
If the engine has electronic ignition, the flywheel key is the timing! Tech. alters the timing by using different keys. I know of at least 3 types, and they are color coded. - gold (anodised), silver, and polished (bright aluminum) If the key shears, the engine may still run, depending on where the flywheel is located on the crank. If the engine has points, check for sheared key, and check the location of the timing - magneto assembly - it may have moved, advancing the timing. Also check point gap - should be .016" Too wide a gap, makes the timing advanced. Some Tech. engines depend on a secondary source of weight on the crankshaft for the engine to run smoothly. If this engine is running bare shafted, it must have a cast iron flrwheel to run properly! the Aluminum flywheel is too light.
Old 06-08-2005, 09:38 AM
Mac Leod Mac Leod is offline
Default Re: tecumseh engine kicks back when starting.
we have a briggs engine that does the same thing...give the cord a tug and get your arm dislocated...I pulled the shroud to see the fly wheel and key (no electric ignition)...all looks fine. the engine was never run when we bought it, it is from the 70's...I thing that perhaps the cam was put in one tooth advanced?
Old 06-08-2005, 08:37 PM
Ken Ken is offline
Thanks Andrew and Mac Leod for your information about my tecumseh 6 hp. It was very helpful when i get ready to tear into it. Im also going to talk to a lawn mower man that sold me the engine. Thanks again!!!
Tecumseh hard starting ryan68bug Small Air Cooled Gasoline Engines 23 12-07-2007 12:04 AM
What have I got, Tecumseh engine Mac Leod Small Air Cooled Gasoline Engines 11 12-05-2007 08:16 AM
Were starting cranks used back when Mike S Antique Gas Engine Discussion 47 11-07-2006 09:55 AM
Back to starting problem ihorse Antique Engine Archives 1 09-25-2004 11:57 PM
kick-back method of starting Doug Wilson Antique Engine Archives 6 08-06-2002 06:59 PM
