fairbanks 3 hp Z not running help
this thread has 2 replies and has been viewed 991 times
Old 06-13-2005, 09:19:46 AM
Havvey Havvey is offline
Default fairbanks 3 hp Z not running help
i have a throttle govern Z very very hard to start seems to have good fire. problem appears to be carb timing or low compression when it runs its very good. how do i trouble shoot would some of you guys hepl? email me thanks.
Old 06-13-2005, 09:56:19 AM
Elden DuRand's Avatar
Images: 6
Default Re: fairbanks 3 hp Z not running help
Probably a sticky intake valve stem or burned valve.
Oil the intake valve stem and work it a few times with your finger. It should move freely.
While cranking slowly, gently hold the intake valve stem back. If you have higher compression when holding it back, you probably have a weak spring.
Take care - Elden
Old 06-13-2005, 04:03:56 PM
Exclamation Re: fairbanks 3 hp Z not running help
Also check the flutter valve at the inlet to the carb. It should cover the inlet completely, and burp a bit when running. it too has a spring behind it, and that spring rusts off too. If you dont hear it, or see it close - check it out. If it does not close, the engine will run too lean at low load, and flood when the throttle is opened
IHC M is Running Away! SethM Antique Gas Engine Discussion 10 01-26-2008 12:10:13 AM
Fairbanks 346 FINALLY running very well DirtbikePilot Antique Gas Engine Discussion 7 10-02-2007 10:16:13 PM
Running vs. non-running engines Chris Kirk Antique Engine Archives 19 12-22-2002 08:02:12 AM
Fairbanks Morse Running Paul. Jones Antique Engine Archives 0 09-13-2002 11:02:33 PM
SLOW RUNNING FAIRBANKS David M. Lyon Antique Engine Archives 6 06-05-2002 07:19:06 PM
