Fairbanks fireing order
this thread has 1 replies and has been viewed 850 times
Old 06-14-2005, 07:56:06 PM
Sky
Question Fairbanks fireing order
Does a fairbanks fire at TDC after the compression stroke or 10 degre's off of the compression stroke? i seem to have forgotten.
just like everything else.
i ask becouse im trying to set the trigger i have made for the model T coil...
Old 06-14-2005, 08:49:04 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Default Re: Fairbanks fireing order
Immediately after the compression stroke is the power stroke. That said, TDC between the compression and power stroke is the very LATEST that you would want the plug to fire. Most engines have a setting for allowing the spark to fire at TDC to prevent kickback when using a hand crank. Once an engine is running, you want all ignition to be at a certain amount of advance, or ignition to occur at a certain number of degrees Before TDC. Thus, if your engine is designed for 10 degrees, it would be ten degrees before TDC or during the last portion of the compression stroke just before the piston starts to go back out of the cylinder. The faster the engine runs, the more you need to advance the timing.
Jeb
Mogul firing help ignitor problems Billy Redden Antique Gas Engine Discussion 9 03-26-2008 09:41:17 PM
ballast fireing an engine Donnie Devore Sr. Antique Gas Engine Discussion 2 09-15-2005 10:40:33 PM
firing order doc Antique Engine Archives 2 10-11-2004 10:15:08 PM
Ever order from Lunkenheimer? Baggsy-Wy Antique Engine Archives 0 09-22-2002 05:50:03 PM
Firing order Tom Johson Antique Engine Archives 2 02-13-2000 07:59:13 PM
