cub cadet original
Does any one know how to check the trans and rear end oil level? I found the level plug on the...
this thread has 2 replies and has been viewed 1928 times
Old 06-18-2005, 04:05 AM
BobRR BobRR is offline
Default cub cadet original
Does any one know how to check the trans and rear end oil level? I found the level plug on the trans. but how about the rear end? BobRR
Old 06-18-2005, 10:20 AM
Mike in NC's Avatar
Images: 62
Default Re: cub cadet original
It uses the same oil for the trans. and rear, all one piece. The trans and rear all made as one unit. It is the same rear as the Farmall Cub uses. So if you need parts or gaskets or seals, you can either go to a Cub Cadet dealer of to a CaseIH dealer.
Old 06-19-2005, 11:17 PM
Thanks Mike. BobRR
Cadet blade mount help Tim B Garden Tractors / Mowers / Scooters 4 12-11-2007 10:52 AM
cub cadet mower clutch HELP BDMelon Garden Tractors / Mowers / Scooters 6 05-27-2007 09:11 PM
Cub Cadet hds 2145 RWBolton Small Air Cooled Gasoline Engines 2 07-30-2005 02:04 PM
Cub Cadet on Steel Don Siefker Antique Engine Archives 5 09-29-2003 10:18 PM
Cub cadet riding mower Vernon Antique Engine Archives 1 04-03-2003 06:08 AM
