Termaat and MonahanHelp! I need information on the operation of the cooling system of a 1HP Termaat and Monahan marine...this thread has 2 replies and has been viewed 1124 times
Help! I need information on the operation of the cooling system of a 1HP Termaat and Monahan marine engine.This engine has a water tube running thru the muffler and either it has a rust hole thru it or the factoy drilled a 1/16th inch hole in the pipe to create some steam to help the exhaust exit. If anybody has any experience with these engines please let me know. Thanks.
Your T&M has an exhaust enrichment system designed and patented by Benjamine Middleditch. The cooling system pump is timed to force water thru the engine as the exhaust port is open. When the engine exhausts its charge, a small amount of water is sprayed into the exhaust stream, thus cooling it. This cooling action helps the engine scavenge the burnt gasses from the engine. A small amount of water also enters the cylender and is compressed with the next fuel-air charge. This helps cool the charge, and prevent detonation, and the water vapor is converted to fuel when the charge is lit by the ignition, adding to the power the engine produces. On the early engines, there was no adjustment to the water charger, and at very low idle, the water tended to back up into the exhaust port, causing serious problems.
At normal idle, and higher running speeds, the system did as designed, and well! This feature was found on all of Benjamine Middleditch designed marine engines!Andrew
im not an "antique marine guy" but, i cant help but be intrigued by the enginuity of these early designers. how the hell did they figure stuff like that out so early on? AMAZING
| Termaat & Monahan Paint Code | Tom Wahl | Antique Gas Engine Discussion | 1 | 11-08-2005 10:29 AM |
| Termaat & Monahan Trip Fingers, does anyone have a pic or know who if any sells them | Roo | Antique Gas Engine Discussion | 4 | 09-13-2005 01:45 AM |
| Termaat and Monahan Serial Numbers | Roo | Antique Gas Engine Discussion | 1 | 05-29-2005 12:11 AM |
| 6 hp Termaat&Monahan | Ray Gardner | Antique Engine Archives | 2 | 12-10-2004 11:32 PM |
| Termaat & Monahan | Rod Gaffrey | Antique Engine Archives | 0 | 07-25-2001 12:28 AM |
