JD E mag tips.
this thread has 5 replies and has been viewed 1628 times
Old 06-18-2005, 10:31:24 PM
Greg Shipley Greg Shipley is offline
Question JD E mag tips.
anyone have a list of dos and don'ts for working on a JD E mag, I have one that does not put voltage out, engine runs fine on a battery and coil.
thanks.
Old 06-18-2005, 11:06:09 PM
BobRR BobRR is offline
Default Re: JD E mag tips.
Do you have the mag timed to the ignitor? BobRR
Old 06-19-2005, 07:38:58 PM
I believe the mag is timed right, as it was running when I got it and I have not taken the mag off.
how do you check?
Old 06-19-2005, 07:54:43 PM
Byron Roberts's Avatar
Byron Roberts Byron Roberts is offline
Greg:; Don't pull the magnet its screws them up...Or mark north and south when working on the base..Byron
Old 06-19-2005, 09:16:06 PM
And don't even THINK of taking it apart without FIRST removing the output terminal--it unscrews just like a bolt.
Old 06-20-2005, 03:05:40 AM
Larry Dunlap Larry Dunlap is offline
Greg,you could try cleaning the copper collector ring inside the mag.Remove the wire,carefuly unscrew the brush holder, inside is the collector ring. I use rubbing alcahol on a Qtip.(you could probably use electrical contact cleaner also) Reach through the tapped hole the brush holder screws into,rotate the mag.Repeat until Qtip quits picking up crud.Also clean the brush and holder with alcahol.I have to clean mine every once in awhile.If you have a copy of the John Deere operating instructions it explains this.Hope this helps,Larry
Tips for First start up of a Fairmont JKWidener Antique Gas Engine Discussion 23 02-03-2008 02:33:17 AM
New to modeling/machining - could use some tips Kenn K Scale Model Engineering 5 12-05-2007 03:13:45 PM
Helpful tips #1 vern0n Antique Gas Engine Discussion 17 09-10-2007 03:13:50 AM
Tips for slowing a T/G engine? Gilbert_Bates Antique Gas Engine Discussion 43 03-15-2007 10:01:22 PM
Tips on starting a JD LUC John Bailey Antique Engine Archives 2 07-17-2003 03:44:56 PM
