Ignition/battery question
this thread has 3 replies and has been viewed 1194 times
Old 06-19-2005, 07:58:17 PM
Chris Kirk Chris Kirk is offline
Default Ignition/battery question
A small upright 2-stroke followed me home from Coolsprings...it's a Caron Bros engine, canadian built, tank cooled. It has a high tension ignition with points, coil, and consensor. It was running at Coolsprings, but when I got it home, I couldn't get any spark, so I replaced the extension cord and speaker wire that made up the ignition system with new 10ga copper wire, and the carbon core spark plug wire with conventional copper-cored wire. I was able to get a spark out of it, and ran it briefly, but then I couldn't start it later. My question is this - I'm using a rechargable 12V battery from a cordless drill for power (I think it's ni-cad), but it seems to go dead very quickly. Do I need to get a motorcycle or car battery, or is there something wrong with the ignition? It's probably that the battery isn't strong enough, but then again, I've used this same battery to run a buzz coil, and it's run for the whole day with not problems. This is kind of new to me, so any help would be appreciated.
Thanks...
Chris
Old 06-19-2005, 09:44:11 PM
Default Re: Ignition/battery question
Chris. It sounds like a new battery is in order.Get a 12 volt lawnmower battery. Joe Morris
Old 06-19-2005, 10:01:45 PM
BobRR BobRR is offline
I would think your battery should work? Are you using a buzz coil or is it as you said?If its as you described you need a buzz coil.BobRR
Old 06-20-2005, 10:49:53 AM
Elden DuRand's Avatar
Images: 6
I don't see any reason your cordless drill battery shouldn't run your engine for a reasonable amount of time if it's in good shape and fully charged.
I'm not familiar with the engine you've got but, if the points are closed most of the time and only open to fire the coil, that could make your battery discharge pretty fast -AND- the coil would quickly get warm to the touch.
Take care - Elden
http://home.cybertron.com/~edurand
Value of battery ignition briggs F? grega Small Air Cooled Gasoline Engines 3 02-22-2008 08:08:11 PM
coil and battery ignition help OldAgIron Antique Gas Engine Discussion 13 11-27-2006 06:40:59 PM
ignition battery Brian Lynch Antique Gas Engine Discussion 11 07-19-2006 07:38:35 AM
New question - Ignition and battery Chris Kirk Magnetos, Ignition Coils and Spark Plugs 3 06-22-2005 04:26:30 PM
F/M 11/2 hp,battery ignition timing Keith Ault Antique Engine Archives 0 08-20-2004 08:04:59 AM
