Fairbanks Mag R to a J
this thread has 2 replies and has been viewed 787 times
Old 06-20-2005, 09:26:40 PM
Ben Bennett Ben Bennett is offline
Default Fairbanks Mag R to a J
Has enyone tried to change a mag (R) on a 6HP fairbanks open crankcase to a (J) magneto with an impulse. It looks like it can be done, but I would appreciate any experienced advice.........Thanks Ben
Old 06-20-2005, 09:45:52 PM
Lonnie Shinn Lonnie Shinn is offline
Default Re: Fairbanks Mag R to a J
IT should bolt up just fine with no trouble. Do you have to install the impulse & gear onto the "J"? If so it will fit just as it does on the "R".
Old 06-21-2005, 08:49:54 AM
David M. Lyon's Avatar
Images: 32
As long as you have the correct gear & impulse, the magnetos will interchange with each other no problem...Same mounting patern, same shaft size... If you want, you can keep your "R" mag and swap the gear & impulse from the "J" to the "R" and maintain it's original look. with the big horseshoe magnet.
David M.
Fairbanks 3hp Z"C" with #3 Fairbanks Light Plant Pix Frank Y Antique Engine Archives 0 03-30-2003 06:32:51 PM
