Waterloo engine
this thread has 4 replies and has been viewed 2398 times
Old 06-21-2005, 06:38:27 PM
Byron Roberts's Avatar
Byron Roberts Byron Roberts is offline
Default Waterloo engine
Does anybody have a pic. of the igniter side ...None of Sponcers seem to have springs for Exhaust rod ...or ignitor trip.. I don't have a pic,... trying to figure it out to many trip to the hardware ...Thanks in Advance .. Byron
Old 06-21-2005, 08:44:20 PM
Doug Kimball's Avatar
Images: 76
Default Re: ::waterloo::
Red one is mine - the green one is one Larry Trammel was or is selling.
Old 06-22-2005, 01:44:10 AM
Images: 4
Smile Re: ::waterloo::
Byron,
Here are a couple of pictures of my 1914 Waterloo Boy 1 1/2 hp taken before I put it in a cart.
This is one of the sweetest engines that I have. At the Tulare show this spring I started it, after a year of not running, on the third pull thru.
After that it started on the first pull even when cold. When warm I could pull it thru very slowly and it would start right up.
I would tell people that it was a great engine but was hard to start then I would pull it thru slowly and they would be amazed that it would fire then slowly pick up speed untill it was up to a slow governor speed.
I run this on a battery and low tension coil.
Old 06-23-2005, 08:10:27 PM
Dick and Doug thanks for the pics. :: Still hard to find springs that fit ..Regular Hardware springs are not what they used on these engines I guess.. Not todays springs anyway:: Every thing seems to be just enough longer or shorter to not work..I have not heard of a Springs~R~ US~ around here.. Still Searching.. Thanks Byron
Old 06-24-2005, 01:31:28 AM
Images: 4
Byron,
If you can find one too long just cut it with side cutter pliers or grind it thru with a grinder at the approximate place you want it cut and bend an attachment loop with needle nose pliers or a small pair of ViseGrip pliers
I seldom find a spring at a hardware store that I don't have to modify to make it work.
My Fuller Johnson has a tension spring on the igniter that I made out of a stainless steel Waterbird spring.
I buy spring assortments from Harbor Freight Tools and others whenever I can find cheap assortments. I also salvage and save every spring that I can that even remotely looks like I might be able to use it.
When I cant find an appropriate one in my collection I try the springs at a good hardware store. If that fails to turn up one I then start looking at other small hardware items like sliding glass door spring assemblies and such.
About all I have ever ordered have been a few valve springs and igniter springs. Although I did just order 24 igniter springs form Starbolt for reproduction Fairbanks Morse Headless Igniters Yesterday.
By the way If any more of you are interested in a Fairbanks Headless Igniter e-mail me and I will add you to the list and give you a price before I have them cast.
daw4224@yahoo.com
Need help on Waterloo Boy 1 1/2hp engine David OBrien Antique Gas Engine Discussion 11 02-13-2006 11:05:46 AM
Waterloo Gasoline Engine Co Stationary tractor engine HHound Antique Gas Engine Discussion 9 12-16-2005 12:10:44 AM
Waterloo engine M.Smith Antique Engine Archives 1 09-29-2004 06:08:06 PM
Waterloo Engine Mike Inglis Antique Engine Archives 6 11-15-2002 05:48:02 PM
Waterloo-2hp gas engine Bob Antique Engine Archives 1 06-20-2001 04:11:45 PM
