Ice Cream Maker Ideas?
this thread has 3 replies and has been viewed 2493 times
Old 06-25-2005, 11:04:17 PM
KeithT KeithT is offline
Cool Ice Cream Maker Ideas?
I would like to make a homemade ice cream maker for my International or Hercules to pull but something different. I saw a Maytag washing machine at the Apple Festival making ice cream but didn't check it closer. Any ideas? Thanks.
Old 06-26-2005, 12:19:27 AM
Images: 4
Default Re: Ice Cream Maker Ideas?
Here is a quick diagram I made for you.
The way I attached the pulley to the crank handle was easy on the crank that I have.
I unscrewed the handle from the shaft and screwed on an allthread nut. The kind that you use to connect 2 pieces of allthread together. Basickely it is a nut that is about an inch high.
I then found a pulley the right diameter that had a hole slightly smaller than the points on the allthread nut. I turned the points on the nut down untill the pulley was a tight fit. If you don't have a lathe you could use a file.
Then I set the screw and screwed in a short piece of allthread long enough to screw the handle back on so that I could check the firmness of the Icecream as it freezes.
Old 06-26-2005, 01:34:05 AM
Rob Skinner's Avatar
Rob Skinner Rob Skinner is offline
Hi Keith,
My wife and I put together an ice cream freezer contraption that we use several times a year as waistlines and guilt permit.
http://engines.rustyiron.com/stable/icecream.html
Old 06-26-2005, 02:26:20 AM
Exclamation Re: Ice Cream Maker Ideas?
The oversize nut Dick was refering to is called a ROD COUPLING. They come in either standard or extra heavy configurations. For 3/8 - 16 size, measuerd by the wrench size, they will be either 1/2" for the std, or 5/8" for the XH. I have seen rod couplings for as small as 1.4 - 20, up to 2"
Ice cream maker plans? Kyle McGee Antique Gas Engine Discussion 15 06-29-2010 05:02:47 PM
Belt Driven Ice Cream Maker steam4fun Scale Model Engineering 6 03-25-2008 02:56:53 PM
Maytag Ice Cream Maker MaytagRepairMan Maytag Engine Collectibles 2 09-19-2007 10:51:54 PM
OT ice cream maker DanR Antique Gas Engine Discussion 4 03-10-2006 08:28:12 AM
How to hook up an Ice cream maker? Kevin Woodruff Antique Engine Archives 26 09-17-2002 09:59:56 PM
