IH LB 1.5-2.5hp 1948 running problem
this thread has 4 replies and has been viewed 1735 times
Old 06-25-2005, 11:57:53 PM
Tom Herd Tom Herd is offline
Question IH LB 1.5-2.5hp 1948 running problem
Just picked up the engine which was restored some time earlier. It fired up right away and ran great for about 20 minutes, then started to run eratic until it stopped. If I increased the speed and adjusted the carburator needle valve I could keep it running - roughly.
It had gas and I don't think venting the tank was a problem - as I opened the cap to check the gas, then restarted it (easily) and it immediately ran rough again. Oil seemed ok as well.
Old 06-26-2005, 02:37:29 AM
Exclamation Re: IH LB 1.5-2.5hp 1948 running problem
check the gas tank vent, make sure it isn't plugged, and check the fuel check valve, it may have dirt in it.
Old 06-26-2005, 09:06:22 AM
Scott's Avatar
Scott Scott is offline
Default Re: IH LB 1.5-2.5hp 1948 running problem
Take a 1/2 dozen clean spark plugs with you to a show. They seem to foul plugs after a few hours of running.
Old 06-27-2005, 01:25:58 AM
Images: 4
Scott,
When I was a teenager my father was a Masonary Contractor who had at least 10 or 12 cement mixers that used those engines.
I found that if after starting them you leaned the mixture as much as you could before they started to run erratically they wouldn't foul the plugs very often.
We had some of those engines that had been run day in and day out for 10 years and they still didn't foul plugs very often.
We did however keep several spares handy.
Old 06-27-2005, 09:17:06 AM
Smile Re: IH LB 1.5-2.5hp 1948 running problem
Scott was correct - the plug was fouled. And in reflection of the last post I believe I was running it too rich. Also the gas cap was ok.
Thanks for all the help.
1948 Alf V-12 Andrew Mackey Antique Autos and Trucks 0 03-22-2008 11:08:30 PM
Decals for 1948 IHC LB 3 - 5hp engine Stevie Antique Gas Engine Discussion 1 03-01-2007 04:20:20 PM
1948 I H Cub David Scott Antique Farm Tractors 0 07-17-2006 09:18:44 PM
1948? Rockol Model B 77 Petey100 Antique Farm Tractors 1 12-30-2005 11:03:38 PM
hurcules running problem Sky Antique Gas Engine Discussion 17 09-16-2005 07:51:13 PM
