Flywheel weight ringLooking for info on flywheel weights. I want to smooth out the engine on my halfbreed tractor. Will...this thread has 5 replies and has been viewed 877 times
Looking for info on flywheel weights. I want to smooth out the engine on my halfbreed tractor. Will the weights help, where would I look for them, would they be helpfull enough to offset what they might cost?? Mine are 54" diameter with 4 bolt holes. Thanks Jim Hunter
Is this a one cylinder engine?
It's doubtful you will get much, if any, improvement in the dynamic balance but you can sure try. Where, in relation to the throw, are the flywheel holes? |
Yes It is a one cylinder halfbreed oilfield engine. I has the additional weight of the cross slide flying back and forth also!! The bolt holes are evenly spaced around the flywheel,one near each spoke. My South Penn has the flywheel a bit thicker on the opposite side from the crank throw and I assume that will help(haven't got it running yet) and it has 2 flywheels. The halfbreed has only one flywheel and a clutch on other side. Thank you much for your interest in my quest for a bit smoother engine! Jim Hunter
Well Jim, I was going to answer your email privately but I might as well take a PUBLIC shot here:
I asked and you told me this engine is running like a conventional 2 cycle engine and firing from the bottom end only. That answered my question.... Which means checking the counterweighting on any single cylinder engine will give you a starting point. Here: http://www.valleymetal.org/Lathe%20S...y%20Engine.jpg is a PERFECT example of a flywheel counterweighted exactly opposite the throw....and that is why I asked if the engine is firing from one end only as the dynamics would change drastically if it was getting TWO opposite impulses. I would START with HALF or less (hmmm...maybe less) the total reciprocating weight as you have only ONE flywheel. An example of how this works was told to me by an old garage owner YEARS ago: 1 ounce of balance weight on a car tire rim multiplies to 60 LBS at 60mph. I had no reason to doubt him then and still don't. You can always bolt on more till you get an acceptable running balance and then make a NICE permanent weight. Craig |
Go to a local salvage yard, and buy some sheet lead. cut into 1" thick by 10" long sections. Take 1 and form it around the rim opposite the flywheel, with the open end facing the rim. Move this weight to various areas and see if the balance improves. When it seems best, add a second, next to it to see if more weight helps. When you find the right amount of weight, weigh the total weight of the strips, and you will know how much weight you need to either remove, or add to balance the engine! I did this on a Hercules 5 HP - it needed over 2 ounces of additional weight removed from the flywheels!
I cannot begin to tell you two, Craig and Andrew, how much I appreciate your responding to my request!!
I now believe I understand what is going on and what I can try in order to try to smooth out operations!! I was thinking that I just needed basically what amounted to another complete flywheel when maybe I'll get away with just adding a few ounces or so to the one side of existing wheel to do the job! Thanks again! Jim Hunter
| Ring ding a ding . Just hear them ring . | kerogas | Small Air Cooled Gasoline Engines | 0 | 01-01-2008 01:03 PM |
| Reid questions on weight and flywheel diameter? | Andrew Mackey | Oil Field Engines | 2 | 11-18-2007 09:06 AM |
| Use an O-Ring for a Piston Ring? | OldironJeff | Antique Gas Engine Discussion | 10 | 08-27-2007 11:00 PM |
| Flywheel weight springs | Doug Edwards | Antique Engine Archives | 2 | 04-04-2003 11:47 PM |
| 12 HP Economy Flywheel weight | Joel Mosley | Antique Engine Archives | 2 | 04-20-2002 12:12 PM |
