Help with IHC type O mag
this thread has 2 replies and has been viewed 1129 times
Old 06-27-2005, 07:29:46 AM
JDBDave JDBDave is offline
Email Not Working
Default Help with IHC type O mag
I need some help with trouble shooting an IHC type O mag. The unit is clean, I have recharged the magnets, I have rebushed the trip end bearing, installed a new end cover with bearing. This is a very simple mag but I have no output. How can I check the continuity of the windings?
Old 06-27-2005, 07:53:00 PM
Ken Majeski's Avatar
Images: 42
Default Re: Help with IHC type O mag
Contineuity can be checked with a simple Ohm meter... resistance should be quite low. These mags transfer energy with a spiral flat spring from the armature. I would look for a bad connection at the spring ends or from the spring to the terminals. If they have been rotated too far the spring is Toast... Are you sure one magnet isn't reversed cancelling the magnetism...???? Good Luck....
Ken Majeski, Ellsworth Wis.
Old 06-27-2005, 11:41:10 PM
Card Sponsor
Is the lead out tower grounding out from bad insulation?How are you testing for current?is the ign. timed with the mag?Is it on a mogul SS,10M,or an 8-16 mogul tractor?There really isn't much to go wrong with these mags.The 1 on my 8 Mogul was outside probably 75 years and after a cleaning and recharging works fine.Rob
What Type Mag ghawk5588 Magnetos, Ignition Coils and Spark Plugs 4 06-24-2007 08:40:06 AM
What Type of Oil Hal Davis Antique Marine Engines and Outboard Motors 4 12-31-2006 06:37:01 AM
What F-M type was this? J Tiers Antique Gas Engine Discussion 4 12-10-2006 10:37:24 AM
IHC TYPE and age GarysToys Antique Gas Engine Discussion 3 03-25-2006 03:15:41 PM
FM type R Mag 3 Darryl Boyd Antique Engine Archives 1 12-19-2003 11:54:04 PM
