2 cylinder horizontal opposed Briggs ? engine
this thread has 2 replies and has been viewed 3581 times
Old 06-28-2005, 12:51:12 AM
MrWizard MrWizard is offline
Default 2 cylinder horizontal opposed Briggs ? engine
this engine is on a 4.5 KW Generac generator from around 1978-80, the CDI module quit sending fire to the ign coil, I have trigger signal and power to the module when the engine cranks, it's on a 6 pin plug mounted on the back of the control box
i'm wondering about replacing it with something from another Briggs or similar engine
ign power measure 20 vac when cranking, but i have 12v DC available if needed
i have the service manual and drawings for the generator, including the engine but generac no longer supplies repair parts for this model
Old 06-28-2005, 07:21:01 AM
Images: 311
Default Re: 2 cylinder horizontal opposed Briggs ? engine
It might be a defective low oil detection unit. I'm going to copy this thread over to the generator board where it might pick up more responses.
http://www.smokstak.com/forum/showthread.php?t=21934
-- Harry
-- Harry Engines Videos Photos
Old 06-29-2005, 12:59:57 AM
Default the coil is bad, CDI ok ?
the oil switch in the resivor is find, i even disconnected it to double check
the switch grounds the ignition stator when the oil resivior is low, it won't even let the crankcase get low
I have power from the stator to the CDI..
made some more checks today, with a digital meter and with the { try & true } hot wiring method
the ignition coil will not spark, even if connected directly to a hot 12 v line ( intermittlely ) or to the stator with 16v AC flashing on & off
service manual says 6500 ohms between the 2 plug wires, and 0 to ground
ground is open on the secondaries and the reading between plug wires is 15,000
I need to replace the COIL
so i need a 2 cyclinder coil, that will fire from this stator or a 12-14 v input using the trigger signal that is already available
I don't care what brand or engine it comes from just so it works
i might try a motorcycle ignition coil if, i don't get any good suggestions
from here
Fairbanks 2 cylinder opposed engine Dan Wiese Antique Gas Engine Discussion 15 12-05-2011 08:48:02 AM
Horizontal single cylinder New Way Engine spfx_dude Antique Gas Engine Discussion 1 09-30-2007 12:21:55 AM
Heer single Cylinder horizontal Rex Pyles Antique Gas Engine Discussion 0 03-26-2006 09:01:19 AM
2 cylinder horizontal opposed Briggs ? engine MrWizard Generators & Motors General Discussion 1 06-28-2005 07:21:01 AM
4 cylinder opposed APU engine Gary McGill Military MEP and Aircraft Gen-Sets 4 03-29-2002 01:22:37 PM
