Spark retarding on a F&J K series engine
this thread has 5 replies and has been viewed 1274 times
Old 06-30-2005, 01:48:21 PM
Forrest A's Avatar
Question Spark retarding on a F&J K series engine
I can't seem to figure out how the timing for F&J series K engines is retarded for starting. Maybe I'm missing some parts that aid in starting or maybe not. Any suggestions?
Forrest
Old 06-30-2005, 06:19:32 PM
Nick's Avatar
Nick Nick is offline
Images: 41
Lightbulb Re: Spark retarding on a F&J K series engine
What size model K do you have? 3, 5 and 7hp have no spark retard nor are they needed. 9, 12, 15, 20 and 25hp have a spark retard built into the ignitor trip finger carrier. Ignitor should snap 18° BTDC when SNAP mark on flywheel rim is centered with pushrod.
Cheers NICK
Old 07-08-2005, 02:02:12 PM
Forrest A's Avatar
Default Re: Spark retarding on a F&J K series engine
It's a 15 HP and if the spark is set per the manual (6 deg. BTDC) it will take your arm off every time it comes up on compression and fires, when it kicks back.
Old 07-08-2005, 04:36:50 PM
Ken Majeski's Avatar
Images: 42
Well... I have never messed with a 15 Hp But.... On the 9 and 12 HP there is a little L Shaped rod sticking out of the Igniter Pawl carrier and you have to turn this to retard the spark.... But... After some wear the dimples in it get worn and turning the rod will have No effect. So you have to Build it up in the right places so it changes the time the igniter will trip. Maybe someone has changed this or replaced it with a bolt or an improper part...
I geuss I could post a Pic of it if you would like.... Probably the 15 to 25 HP would have something similar I would geuss...
Ken Majeski, Ellsworth Wis.
Old 07-08-2005, 06:50:54 PM
Nick's Avatar
Images: 41
According to my 15-25K parts list these engines have the same ignitor trip carrier with early/late starting lever. As Ken mentioned sometimes this rod gets a dimple worn in it, then it don't work as intended. Lever is only a length of 1/4 rod with a few holes drilled for pins and a flat milled on one side.
Cheers NICK
Old 07-11-2005, 01:51:01 PM
Forrest A's Avatar
No pictures at this time but thanks for the details.
Forrest
Cummins A Series (Onan L Series) L423D fuel pump problem? ichudov Onan Generators 23 09-22-2015 08:36:44 PM
Case R Series Engines (RE Engine ??) Bud Tierney Antique Farm Tractors 3 03-23-2008 07:32:57 AM
Briggs R series engine Motormowers Small Air Cooled Gasoline Engines 0 07-14-2007 02:01:08 PM
l series diesel engine lucas34 Onan Generators 18 11-10-2006 05:06:42 PM
Can anyone ID these J series diesels, plus engine coupling questions ichudov Onan Generators 14 10-14-2006 07:30:24 AM
