Help Needed on Little Major
this thread has 1 replies and has been viewed 1061 times
Old 07-02-2005, 07:44:16 PM
Will's Avatar
Will Will is offline
Default Help Needed on Little Major
I picked up this small engine today in a swap. Worked hard on cleaning the carb, oiler and mag and was able to get it started. My question is: there is a place for the muffler to go on the top of the head like it should. About four inches below it there is another spot that has been machined for another pipe of some kind with what looks like a tin plate with some small holes in it. When I roll the piston over you can see the piston come flush with the hole. Ok, so here the problem, When I got it running it vented it's exhaust out the bottom hole instead of out the muffler. I took the muffler off and it looked clean all the way to the exhaust vavle which seems to be working just fine.
It's a nice little engine but this one has me confused. Also, how does the rod bearing get it's oil as there dosent seem to be any way for it to get any oil. The only drip oiler is the one for the piston.
Thank you,
Will
Old 07-03-2005, 06:49:49 AM
Images: 17
Default Re: Help Needed on Little Major
Will: Thats a ported exhaust engine and the muffler belongs on the side port. As for the oil, if I remember right, I belive it's splashed up from the crankcase. A neat little engine, I used to own one awhile back.
Did you make a new friend today, and a lot. Paul - "OLDIHC"
Fordson Major Diesel, Power Major, & Super Major David K Antique Farm Tractors 26 09-25-2015 12:59:55 PM
IHC Tom Thumb - major tuning needed! Harry Antique Gas Engine Discussion 3 04-29-2007 06:02:01 PM
Stewart "Little Major" help needed Dave Beck Antique Gas Engine Discussion 4 09-01-2006 12:22:32 PM
Stewart little major Ihorse Antique Gas Engine Discussion 1 04-17-2006 03:02:10 PM
Lunkenheimer Major oiler pix needed PaulGray Antique Gas Engine Discussion 0 05-09-2005 07:59:55 PM
