Castiron or steel
this thread has 5 replies and has been viewed 1497 times
Old 07-05-2005, 08:17:24 PM
Robert Voice Robert Voice is offline
Default Castiron or steel
I just took my 8 hp famous cylinder to the machine shop to be sleved. The machinest ask if I wanted a castiron or steel sleve. The cost appears to be about the same. What is the pros and cons to the two types of metal? What about piston clearence if steel is used.
Thanks for your help.
Bob Voice
Michigan
Old 07-05-2005, 08:57:08 PM
Keven Withers's Avatar
Keven Withers Keven Withers is offline
Images: 15
Default Re: Castiron or steel
Use cast iron The rings will be much easier to seat. We have used a few steel sleeves and have not liked them very well. Keven
Old 07-23-2005, 03:48:07 PM
ListerDiesel's Avatar
Go with cast as Keven already suggested, CI is better for wear and oil surface retention than steel, but you can use steel if you are careful with ring material selection.
Most liners are centrifugally cast, cast iron.
Peter
Old 07-23-2005, 04:10:40 PM
Ray Cardoza's Avatar
ci can handle the heat a little better than the steel liner can
Old 07-24-2005, 12:06:30 AM
Neill Neill is offline
I don't know how much material your taking out, but you could sleeve the piston instead (steel works well) . My grandfather has done this with much success. Good luck to you.
Neill
Old 07-25-2005, 12:51:13 PM
Tony Leonard's Avatar
Tony Leonard Tony Leonard is offline
Default Re: Cast Iron or Steel
I have sold both Centrifugally Cast and Continuous Cast Iron to be used for sleeves and both have worked well but you definitely need to use Gray Iron. Ductile Iron is stronger than Gray Iron but it does not have the wear properties that Gray Iron has.
I have a 1-3/4 HP Economy engine that was sleeved with a steel sleeve before I bought it and it has always had blow-by and low compression problems. I know there are many factors that can cause these problems but I have had several folks look at the engine and comment on how they don't think the rings have ever seated correctly due to that steel sleeve.
Just some more food for thought.
Tony Leonard
Rockwell, NC
Whaddya think? (steel wheels on a steel deck) MoRo Trucks, Trailers and Hauling for Shows 10 02-15-2008 05:53:33 PM
Steel cylinder? Richard H. Gambrell Antique Gas Engine Discussion 13 12-28-2006 10:56:06 PM
artist in steel Dan Baalman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 12-07-2006 03:28:02 PM
Fordson on Steel and others Jim Tremble Antique Farm Tractors 10 06-04-2005 10:20:25 PM
CASTIRON wheels Byron Roberts Antique Engine Archives 0 03-22-2004 08:20:24 PM
