Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag 92 side exhaust parts breakdown
Anybody know where I can find an exploded view parts break down for a 1927 Maytag 92 side exhaust?...
this thread has 1 replies and has been viewed 603 times
Old 07-12-2005, 10:35 AM
Chris Curtis
Default Maytag 92 side exhaust parts breakdown
Anybody know where I can find an exploded view parts break down for a 1927 Maytag 92 side exhaust? I have searched the web and found parts list and a lot of info. but no pictures or exploded views. Also, can the rod bearing be shimmed like a big engine or is it a replacable insert? Thanks
Old 07-12-2005, 06:06 PM
Exclamation Re: Maytag 92 side exhaust parts breakdown
No shims on the rod. If it isnt worn too badly, try using a file to remove a little metal from the capyou need a couple of thousandths of clearance. If the rod is badly worn, or is egged, you may have to replace it. Try Simpson's motors, Larry should be able to help.
Sheffield halfbreed weight breakdown Frank Stenger Oil Field Engines 1 02-07-2007 11:27 AM
Wanted parts breakdown for IHC Gene Fisher Antique Gas Engine Discussion 2 11-19-2005 11:58 PM
maytag exhaust Brickman Maytag Engine Collectibles 11 09-23-2005 11:53 PM
connecting rod play (side to side) Jebaroni Antique Gas Engine Discussion 5 06-05-2005 02:56 PM
Maytag Twinn Exhaust ?? Steve Gerot Antique Engine Archives 5 03-22-2002 09:47 AM
