Fuller & Johnson NA Wiring Diagram
this thread has 1 replies and has been viewed 1085 times
Old 07-15-2005, 08:48:02 PM
Larry K Larry K is offline
Question Fuller & Johnson NA Wiring Diagram
My 3 hp. Fuller & Johnson, model NA, has a low tension Splitdorf magneto. Does this magneto need a buzz coil to boost the electrical output or does the wire run from the nut on the right side directly to the switch that goes to the ignitor? It is a 1923.
Thanks.
Old 07-16-2005, 10:46:17 AM
Elden DuRand's Avatar
Images: 6
Default Re: Fuller & Johnson NA Wiring Diagram
Thanks.
Larry:
The output of the magneto goes directly (through the switch) to the ignitor. I've never seen any kind of low tension mag setup that requires an external coil.
I will make an exception! I had an American LaFrance with an Eisemann GR-4 magneto on it that would generate low-tension juice to fire the high-tension coil that came with it. The coil was mounted in a housing that acted as a switch to switch the source of voltage between the battery and the magneto. You'd switch it to "Battery" and, after you got the monster turning over at some speed, you could switch it to "Mag".
The high voltage output of the coil went through the distributor on the mag and then to the plugs.
Take care - Elden
Onan CCK Wiring Diagram BTPost Onan Generators 9 07-08-2012 12:21:40 PM
Wiring diagram peluka Onan Generators 3 02-28-2007 08:51:37 PM
Wiring diagram Applejack Generators & Motors General Discussion 0 07-17-2005 11:03:17 AM
Wiring Diagram 12.5JC/3CR GeorgeP Onan Generators 0 07-16-2005 06:40:04 PM
CMC wiring diagram oldtime Generators & Motors General Discussion 0 04-06-2002 09:53:24 PM
