FM Headless
this thread has 1 replies and has been viewed 1112 times
Old 07-19-2005, 12:46:34 AM
ErikG ErikG is offline
Default FM Headless
I finally got the stuck piston out of my FM Headless last week!!! I used electrolysis from the front and the back, then tipped it up and used penetrating oil in the bore, then took Stakers advice and made a plate with a zerk fitting attached for the igniter hole. Filled the combustion chamber most of the way with tranny fliud put the plate on and started pumping grease. I took initial measurements and after 20 or 30 pumps I was very suprised. It moved! The cylinder is badly pitted and will try the JB Weld idea. The piston ring grooves are worn so I will turn the piston on the lathe and install new rings with spacers.
I'm missing the original steel skids so I will make new ones out of oak. Could someone give me the steel skid dimensions?? I would like the overall length and distance from the front of the skid to the first mounting hole.
Thanks in advance,
Erik Grund
Bloomington, MN
Old 07-19-2005, 07:20:29 PM
Will Batty's Avatar
Will Batty Will Batty is offline
Images: 33
Default Re: FM Headless
Eric
I will not be home till Friday night, but if you do not have a response by then I will measure up my skids at home and pass them on to you.
Will
FM Headless ErikG Antique Gas Engine Discussion 12 04-11-2006 04:13:07 PM
F-M Headless Mag. Dan Donaldson Antique Engine Archives 5 12-07-2004 10:01:11 AM
HELP!...FM Headless..... Warren Pennington Antique Engine Archives 3 04-23-2004 06:33:09 AM
F&M headless HELP! Greg Downard Antique Engine Archives 2 11-24-2003 04:48:25 AM
FMZ Headless 1-1/2 Larry Antique Engine Archives 2 04-29-2003 10:29:09 PM
