| Antique Gas Engine Discussion Meet collectors of hit and miss engines, ask questions about collecting, restoring and showing antique flywheel engines. |
Gib keysI had a oroblem with the gib key working loose on a small engine that I had. I could drive it in...this thread has 6 replies and has been viewed 1179 times
I had a oroblem with the gib key working loose on a small engine that I had. I could drive it in tight and after the engine ran a while the key would be loose again. It turned out the problem was the fact that the key was a little too long and about the same time it was getting hard to drive in enough to hold the flywheel tight it was reaching the end of the machined keyway of the crankshaft. So, it was bottoming out before it was really tight enough to tighten up on the flywheel itself. Sawed about 3/8" off the end of the key and solved the problem. I just thought this might help someone in the future haveing a problem such as this when a wheel won't stay tight. Joe Morris
Joe:: Thanks for the Heads Up...On my type A United the govenor side flywheel keeps coming loose ....drove on the gib a couple times..Its loose now after last show....Something I have had my eye on...I will pull the key and Shave it off .. Kind of knew what I needed to do ..But was wondering what keeps making it work lose....Thanks Byron
Make sure your flywheel hub isnt cracked, a wobbled out keyway will let them work loose also!
BobRR
Bobbr:: No wobble in flywheel..Just key working loose..It runs ok.. Thought it was original..Maybe Not..Byron
Go to this link. It will make you want to check every thing over before you start up the old motor again.
http://royalcrossfarm.com/Failure.html |
Intresting to see that the engine which has blown itself apart under the title reg ingold, has paint covering alot of the fractures on the casting, Meaning they where there before he started it, never take any risks with castings, go over them with a fine tooth comb before painting them.
Did you check out the Galloway? What a terrible turn of events
| Associated flywheel keys | John Dungan | Antique Gas Engine Discussion | 10 | 09-07-2007 07:14 PM |
| Woodruff Keys | Jonathan Widelo | Antique Engine Archives | 2 | 09-25-2004 10:54 AM |
| Measuring gib keys | Jim Sherman | Antique Engine Archives | 2 | 06-17-2003 12:45 AM |
| Tapered Gib Keys | stan agacinski | Antique Engine Archives | 7 | 10-27-2002 03:27 PM |
| flywheel keys | larry harding | Antique Engine Archives | 13 | 08-06-2000 07:24 AM |
