Need help with IHC Famous Tank Mounting
this thread has 5 replies and has been viewed 1489 times
Old 07-24-2005, 09:37:32 PM
Peter Peter is offline
Default Need help with IHC Famous Tank Mounting
I just got a new thermosyphon cooling tank from John Wanat for my 1906 3hp IHC vertical famous. Very nice. I need to know how to tie the tank down. Exact size rod, number of rods and how the top ends looked. If someone could post a photo or send me an image of the tops, it would be very helpful.
I also wonder if it matters how the exhaust pipe and top water pipe are routed. I hate to guess wrong. I like the look of the muffler running direct up and higher than the tank top. And water pipes fudged around a little at a 45 to the engine and tank.
Thanks in advance,
Old 07-25-2005, 05:06:05 AM
John Hammink's Avatar
John Hammink John Hammink is offline
Default Re: Need help with IHC Famous Tank Mounting
Peter show a picture of your new tank, I'm afraid you're mixing up two different things.
Old 07-25-2005, 06:40:34 AM
The cooling tank is approx 18 inch by 52 tall and must be attached to the skid with long rods. I am asking rod diameter: 1/4 or 5/16, quantity: 3 or 4 and end treatment: bend over or little castings on the ends.
Second, from a purely cosmetic point (function I understnad) is there a certain way the two water pipes must be run to the engine? Right now the water line from the head has to sneak around the exhaust pipe.
Old 07-25-2005, 07:11:51 AM
I have never seen an original vert. engine with thermosyphon cooling, even a picture or image. So I can't tell you that. In all my books, no image of that.
The only part # I can find are the flanges for the tank, round flanges rivetted to the tank and good for ˝ " pipe.
For thermosyphon cooling the water level in the tank, always has to be above the head level. I think you have to find someone that has an original setup.
Old 07-25-2005, 12:15:56 PM
Images: 17
The book 150 years of IHC by C Wendell on page 111 shows a vertical pump engine with the tank you have. Even shows the piping you are asking for. I know Rob has one he was working on.
Did you make a new friend today, and a lot. Paul - "OLDIHC"
Old 07-25-2005, 02:01:09 PM
Yes Paul that's it. Never seen that pic in the book after hundred times looking from page one to the end. Thanks.
2 HP Famous gas tank Greg Shipley Antique Gas Engine Discussion 1 12-19-2007 01:03:48 PM
What did Original FM Fuel Tanks look like? Correct Mounting of NEW Tank? DerekC Antique Gas Engine Discussion 12 11-14-2007 07:58:28 PM
Help with IHC Famous cooling tank E.C. Mims Antique Gas Engine Discussion 14 10-04-2007 08:09:40 PM
4hp famous tank Eric McKenna Antique Gas Engine Discussion 3 11-27-2006 10:32:31 PM
Autosparker mounting 10hp Famous Dale Fye Antique Gas Engine Discussion 0 06-04-2006 11:32:46 AM
