Welding Shop
Generator/welder
Hi All, I have an old generator/welder(wwII or Korea era). It has a stamp on it that says it was...
this thread has 4 replies and has been viewed 2393 times
Old 07-25-2005, 07:57 PM
AJH AJH is offline
Default Generator/welder
Hi All,
I have an old generator/welder(wwII or Korea era). It has a stamp on it that says it was made for the airforce and army, and it has a Bendix Aviation generator on it, if that helps. What I need to know is if there is any way to make the welder burn COLDER(for lack of a better term). I've had it set to its lowest settings, and I'm lucky if I can weld 1/8 in steel. It always burns through. Is there anyone here that knows anything about these welders and could possibly give me some tips on welding thinner metal with it?
AJH
Old 11-19-2005, 01:17 AM
Doogdoog Doogdoog is offline
Default Re: generator/welder
Aloha,
How do you set it to it's lowest settings ? Is it a switch, rheostat? "I've had it set to its lowest settings"
Mahalo,
doogdoog
Old 11-03-2007, 02:55 AM
Giles Giles is offline
I have a old airco welder that has the same issue / some of these older welders have a magnetic amplifier much like a transformer unfortunatatly this is the heart of the machine and finding some one to rewind the mag amp is costly / So I bought the wire seven years ago and still don't have all the knowledge to fix it. Maybe I will wait till copper goes through the roof again and scrap it. I currently have four dead weldors and three alive and well sorry I didn't help much good luck / if it is a reastat this is a much cheaper fix
Old 11-04-2007, 10:48 AM
Default Re: Generator/welder
perhaps a KISS solution...just use longer cables? it will get you further from what is probably a noisy welder anyways!
Rob
Old 12-02-2007, 07:32 PM
Martin Draper Martin Draper is offline
Do`nt know if this will help but here`s a page to order the original manual from
https://www.hobartwelders.com/owners...oldmanuals.php
Need Help, Onan generator/welder Warren Fehr Onan Generators 0 10-08-2007 08:23 PM
Hobart Welder/Generator Martin Dollar Welding Shop 2 12-23-2006 02:47 PM
Old welder- generator ? linc1fl Antique Gas Engine Discussion 0 03-24-2006 02:54 PM
generator/welder Eric Pope Generators & Motors General Discussion 3 10-19-2004 09:33 AM
welder generator Harold Stotts Welding Shop 1 12-15-2002 03:20 PM
