ignition And valve timing
this thread has 3 replies and has been viewed 1832 times
Old 07-26-2005, 11:23:08 AM
Doug Waggonner's Avatar
Question ignition And valve timing
Ok, this is a little off topic, but I dont think there is any other place on the web where so much knowledge can be found. I am in the process of converting some diesel engines to spark plug ignition natural gas engines. Well I got the easy part done, it runs! My problem is this engine jumps at any speed and it didnt as a diesel engine. My question is, what can I do so calm this engine down. I've got the spark timing at 2 degrees before TDC. I think if i change the valve timing it may help? The "standard" for valve timing for diesel vs. gas is bound to be differant right? This engine will be working around 800 rpm and less. What to you guys think? Thanks in advance
Old 07-26-2005, 11:45:46 AM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Default Re: ignition And valve timing
Well, with the compression that a diesel engine generates, I would be concerned with pre-ignition. Unless you are injecting the natural gas, I have a feeling that it is pre-igniting and the spark plug may not be doing a whole lot. 2 degrees BTDC would stall most engines unless they were running VERY slow. Just out of curiosity, try pulling the spark plug wire while it's running or grounding the wire out and see if it still runs.
Jeb
Old 07-26-2005, 12:33:06 PM
I've got a carb on the engine, not injecting the gas. I can turn the key and kill the ign system and the engine dies. So its not actually running like a diesel. I will check the compression ratio, if its really high that too may be a reason for the engine jumping so hard?
Old 07-26-2005, 08:20:11 PM
Elden DuRand's Avatar
Images: 6
Doug:
The compression of a Diesel designed engine is too high for NG or gasoline spark ignition use. You might want to add one or two extra head gaskets to lower it to below about 8:1 or so.
Take care - Elden
15.0JC Vacuflow Ignition Timing pcbye Onan Generators 2 05-20-2007 07:08:50 PM
F/M 11/2 hp,battery ignition timing Keith Ault Antique Engine Archives 0 08-20-2004 08:04:59 AM
Ignition Timing on a MC D 1 1/2 Paul S. Antique Engine Archives 9 04-19-2003 12:26:45 PM
Witte Ignition timing Bob Naske Antique Engine Archives 3 07-06-2002 04:56:43 AM
Ignition Timing ? Craig Daigle Antique Engine Archives 1 02-20-2002 07:33:01 PM
