Canvas belting- 1"
this thread has 3 replies and has been viewed 1626 times
Old 08-02-2005, 07:51:11 PM
PaulGray's Avatar
PaulGray PaulGray is offline
Images: 38
Default Canvas belting- 1"
Anyone know who sells canvas belting at 1-1.5" wide. I have a project in need of ~10'. I have a clipper lacer so will not be a problem with joints. Thanks-!!
Old 08-02-2005, 08:47:38 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Default Re: Canvas belting- 1"
I beleive that Hit-N-miss enterprises sells belting that thin. If not that thin, you can check with your local hydraulic hose/industrial rubber supplier. My local guys (Haynes Rubber Co.) sell belting and can also split/slit belting that is too wide down to a custom width. Just so you'll know, you normally run belting about 1/2" narrower than the pulley. That doesn't always apply, but might be helpful to know when you run across a 5 1/2" pulley.....
Jeb
Old 08-02-2005, 08:48:59 PM
Jebaroni's Avatar
I should also let you know that clipper lacing comes in two varieties. Galvanized (mild steel, easy to use with the lacing press) and High-tehsile steel. Hi-ten is very hard to crimp with the lacing press unless you have the industrial roller version. If you can get galvanized, go with it and get plenty of it since it is beginning to be phased out.
Old 08-03-2005, 12:08:54 AM
JKKD JKKD is offline
I get my belting from McMaster-Carr, http://www.mcmaster.com/ . Search for "flat belt". They have all types and sizes. I generally get the light duty type. I get my order in 3 days or less.
Jamie
McCormick Canvas conveyor? JKWidener Farm + Industrial Antiques and Collectibles 30 02-17-2008 07:11:30 AM
Are there any canvas covers available? Karl T Schwab Antique Gas Engine Discussion 2 05-24-2005 11:40:17 PM
PE-75 canvas cover N.O.S John Rolli Generators & Motors General Discussion 1 08-16-2004 08:47:32 AM
Belting up Frank Y Antique Engine Archives 2 01-12-2003 10:25:41 PM
Canvas Drive Belt Tom G Antique Engine Archives 2 04-07-2002 10:27:43 PM
