Slowing an engine down
this thread has 9 replies and has been viewed 2156 times
Old 08-02-2005, 10:18:39 PM
Rich Martz's Avatar
Rich Martz Rich Martz is offline
Images: 23
Default Slowing an engine down
I have a nice little 1-1/2 Hercules Hit and Miss engine that runs great at rated speed. I would like to slow it down. Do I need to change some springs? Any help would be great. Thanks .........and Thanks Harry
Old 08-02-2005, 11:09:31 PM
Rick I Rick I is offline
Default Re: Slowing an engine down
I can't comment on the springs, but I do know you'll have to retard the timing in order to get it to 1) run well and 2) avoid damaging stress on the engine's crankshaft, etc.
-Rick I.
Old 08-02-2005, 11:35:33 PM
Bob Ronning's Avatar
Bob Ronning Bob Ronning is offline
Images: 4
Rich, yes you need to replace the spring with a lighter one. Are you going to be at Franklin Grove on Sat. I could show you how to change it. Bob
Old 08-03-2005, 01:51:02 AM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
Rich I have a 1926 2hp Jaeger and a 1915 1 1/2 hp Economy which I slowed down by putting weaker springs in the govenor. You take the gov.weights off and pull pin and use weaker and shorter springs. Timing is almost TDC. They are running an actual 166 rpm.(I count cam hits on pushrod for 1 minute ,times two gives exact RPM'S).Dick in central PA.
Old 08-03-2005, 09:23:56 AM
Rick Strobel's Avatar
Rick Strobel Rick Strobel is offline
Images: 20
And the J mixer will probably drool a little when the engine is slowed down..this is normal for a Herc/Economy.
RickinMt.
Old 08-03-2005, 09:58:14 AM
JKKD JKKD is offline
Along with putting a lighter spring in the governor, you may also have a little spring behind the latching finger that could stand to be lighter. Also adjust the latching finger so that it just clears the latch plate when it's set to run the slowest. You'll also have to keep the choke most of the way closed when running slow. To get around this I machined a smaller venture, which ended up being horseshoe shaped, to drop into the mixer on my 7E Economy. I made no modification to the mixer its self. It is held in place by the needle valve passing through it. Now my choke is wide open and I get no more fuel drips while running. To start the engine I close the choke, roll the engine to the point I can latch the exhaust valve and hold it latched while I spin the engine up. Once the engine is turning good I release the latch and continue pulling the flywheels through compression. If the engine is cold it will fire on the 2nd compression stroke or sometimes the 3rd. If it's warm it will usually go on the 1st. Once it fires I open the choke fully and I'm done.
Good luck,
Jamie
Old 08-03-2005, 09:14:33 PM
Rich Martz's Avatar
Images: 23
Thanks Guys......down to 175 rpm. Changed the governor spring, latch spring and adjusted the latch. Might try for more (less) later but now it is running nice and slow.......Thanks again to all who replied.
Old 08-03-2005, 10:37:39 PM
Mac Leod Mac Leod is offline
I have had my herc. 3 horse down to about 90 RPM...gov spring was a former techumseh valve spring...I coverd the mixer intake with foil that had a few pin holes in it...and cut way back on fuel
works for me
Old 08-04-2005, 05:30:14 AM
Alan in KY
hey rich you are running the same as my ole k a stover now 175 now im going to have to cut that governor spring again alan
Old 08-04-2005, 10:16:28 AM
Elden DuRand's Avatar
Images: 6
Rich:
Make sure you retard the ignition timing to close to TDC to lessen the strain on the crankshaft. This will also let the engine run slower.
Take care - Elden
Tips for slowing a T/G engine? Gilbert_Bates Antique Gas Engine Discussion 43 03-15-2007 10:01:22 PM
for me smokestak is slowing down BobM Computer, Camera and ISP Problems 3 12-07-2006 06:13:33 PM
Slowing an Economy Greg Shipley Antique Gas Engine Discussion 9 05-03-2006 09:15:11 PM
Slowing down a 1927 Economy 1-3/4hp Karl T Schwab Antique Gas Engine Discussion 5 05-23-2005 09:35:39 PM
slowing down engine Randy Antique Engine Archives 7 08-04-2004 09:54:32 AM
