FM Dishpan-rockerarm removal
this thread has 6 replies and has been viewed 1206 times
Old 08-04-2005, 02:29:32 PM
Charles Cooley Charles Cooley is offline
Default FM Dishpan-rockerarm removal
I recently bought a new rockerarm spring to replace the current broken one. I have not figured out how to remove the rockerarm. The bracket which it is mounted on is easily removed from the head but to remove the fulcrum ??from the bracket is my problem. I have removed the nut, now how to get the bolt or whatever it is called out?? Thanks
Old 08-04-2005, 02:36:54 PM
Bruce Wambach Bruce Wambach is offline
Default Re: FM Dishpan-rockerarm removal
Charles,
Are you refering to the exhaust valve spring? If so, there should not be a need to remove the rocker arm to replace the valve spring. You should have enough clearance to replace the spring with the rocker left on. I changed both the intake and exhaust valve springs not long ago on my dishpan without removing any but the "keepers" on the valve stem.
Bruce in PA
Old 08-04-2005, 05:09:49 PM
Dan Baalman Dan Baalman is offline
Charles the pivot pin is tapered slightly and can be a booger to get out. Must go out opposite the threads. A little heat should do the job. Good luck. Dan
Old 08-04-2005, 06:35:11 PM
Dan ,
Thanks for the reply. Do you drive it out from the top?? I do not understand the purpose of the nut on the bottom. Removing this did nothing. Thanks again
Old 08-04-2005, 07:08:55 PM
Vincent Abbatiello Vincent Abbatiello is offline
Email NOT Working
I have the same problem with the rockerarm! Where did you find the spring.
Vince
Old 08-04-2005, 08:30:59 PM
Darryl Boyd's Avatar
Darryl Boyd Darryl Boyd is offline
Maybe this image will help a little. It is not exactly true or perfect, but shows the condition Dan was trying to explain.
Remove the nut and tap it back the direction of the arrow (with a little heat). That will loosen up the taper on the other end.
Actually I loosen the not about 1/2 way off and tap on the nut instead of the threads.
DB
Old 08-05-2005, 10:54:59 AM
Thanks to all,
Thanks for all your advice. To Vince, spring was purchased from Hit N Miss enterprises.
Charles
Who's got a rockerarm for sale??? Chris Page Antique Gas Engine Discussion 2 03-23-2008 01:36:49 PM
Mag for FM 2 hp dishpan GarysToys Antique Gas Engine Discussion 11 01-04-2007 11:39:23 PM
rockerarm for 6hp gray engine HBurk Antique Gas Engine Discussion 1 02-18-2006 10:09:26 PM
Dishpan Governor Gear Removal. Jim Gorter Antique Gas Engine Discussion 5 02-01-2005 10:37:59 PM
Fairbanks dishpan flywheel removal Russ Hughes Antique Engine Archives 0 10-12-1999 04:01:28 AM
