Ruug mowers?
I picked up 2, may try to build one that works from them. Look to be late 60's early 70's....
this thread has 2 replies and has been viewed 797 times
Old 08-07-2005, 12:13 AM
JohnL JohnL is offline
Default Ruug mowers?
I picked up 2, may try to build one that works from them. Look to be late 60's early 70's. Turquoise paint. Reel mowers, B&S 2 hp horozontil engines, drive wheel rubber needs replaced, any info on this company?
thanks
john
Old 08-11-2005, 09:27 AM
Mike S's Avatar
Mike S Mike S is offline
Default Re: Ruug mowers?
I have a Rugg riding mower and have seen quite a few others; but I haven't come across any reel mowers.
You can get tires from Miller's Tire. They will send you a catalog for free. I can get their address for you.
What is the model of the engines? Do they have a serial number or code number? If there is no tag, are they cast iron or aluminum? How many fins are on the side of the cylinder?
Old 08-11-2005, 06:38 PM
These are aluminum, model 60102 from memory. Don't recall the code, though the year referenced was late 60's to early 70's, probably 71. One is completely seized, the other had a dirt nest in the muffler and exhaust port, but now runs.
The second mower may not be a Rugg, very close in color but says ASA on manufacture tag, probably a different make.
john
Whiz-Mow lawn mowers Tony Kimmell Garden Tractors / Mowers / Scooters 3 02-26-2009 04:01 PM
Reel mowers youngmaytagstud Garden Tractors / Mowers / Scooters 7 01-24-2008 03:18 PM
History of grass mowers? Delta Dirt Farm + Industrial Antiques and Collectibles 1 05-21-2007 12:16 AM
rugg mowers 23rugg Antique Gas Engine Discussion 0 07-29-2006 01:13 AM
sensation mowers Robbie Ramey Antique Engine Archives 1 02-14-2002 10:44 PM
