McCormick 1.5hp 1921
Two questions - concerns. First; it runs fine on battery and coil, but won't run on magneto (I do...
this thread has 2 replies and has been viewed 743 times
Old 08-07-2005, 07:27 PM
Tom Herd Tom Herd is offline
Default McCormick 1.5hp 1921
Two questions - concerns. First; it runs fine on battery and coil, but won't run on magneto (I do get spark). What I noticed was the timing. The two marks on the exhaust cam driver cover when extended as a straight line (flywheel in IGN position) do not intersect with the magneto shaft as described in the instructions. My guess is the previous owner missed a tooth when it was apart - perhaps. How accurate does it have to be? And if it has to be right on (logically it does) then I guess I will have to tear it all down and reset the internal gears.
Second question; the fuel pump works, but barely. The book mentions packing - where and what do I use if I disassemble it for repair?
Old 08-08-2005, 12:25 PM
John Hammink's Avatar
John Hammink John Hammink is offline
Default Re: McCormick 1.5hp 1921
Tom, you almost answered your own Q's. Yes it's importend that the notch on the armature match the notch at the bushing. When the crank gear and cam gear are in line, the easiest way is to remove the magneto and place it back the good way. Take the top half of the governor side bearing away and with the help of an electric torch you can see the marks on the gears ( if they exist, some haven't ).
For packing, I always use the threads of a household floor mop, some old fashion soap and it works for years. Check the balls in the pump, when they are brass they will be egg shaped. New steel or stainless will do the job.
"Sixm" John
Old 08-10-2005, 06:15 PM
Thanks for the tip. After the show, in 2 weeks, I will have to get into it and correct the minor problems.
1921 Waterloo Boy mike r Antique Gas Engine Discussion 2 06-22-2006 12:04 AM
1921 Waterloo Boy ? mike r Antique Gas Engine Discussion 0 06-15-2006 09:07 AM
1921 15-30 Ihc Kevin A. Behnke Antique Tractors - Old Iron Lugs, Cleats and Tracks 9 12-12-2005 02:05 PM
Stationary Engines About 1921 Don Siefker Antique Engine Archives 7 04-17-2004 09:15 PM
Correct color for 1921 Reid 15 HP Pete Antique Engine Archives 0 07-07-2002 10:31 PM
