22.5 Bessemer / spark plug arc
this thread has 5 replies and has been viewed 1094 times
Old 08-10-2005, 09:48:51 AM
Mike Helmick Mike Helmick is offline
Default 22.5 Bessemer / spark plug arc
Having a little trouble starting a 22.5HP Bessemer lately. It doesn't want to fire initially on the gasoline primer. Took the mag off & charged it & have same problem. The spark plug is a Champion type 43 (34 or 43? cant remember). Has two points for the spark to arc. When I checked it, it only arcs to one point. Should it go to both?
Thanks.
-Mike
Old 08-10-2005, 10:39:59 AM
Elden DuRand's Avatar
Images: 6
Default Re: 22.5 Bessemer / spark plug arc
Thanks.
-Mike
Mike:
On those two electrode plugs you can never get both gaps EXACTLY the same and you will only get a spark to one of them or the other. This is because the one with the smaller gap will fire first and suck-up all the juice so the voltage never rises high enough to fire the larger gap.
Take care - Elden
http://home.cybertron.com/~edurand
Old 08-10-2005, 02:22:54 PM
Thanks for the reply, Elden. What purpose did the dual points serve?
-Mike
Old 08-10-2005, 02:56:47 PM
Doug Waggonner's Avatar
Well, in thery if one gets dirty, carboned up ect, it would just jump to the next best place. Instead of just quit firing all together. Now weather this is the case or not i'm not sure. But its a good idea, and becides that they just look cool
Old 08-10-2005, 04:13:20 PM
Exclamation Re: 22.5 Bessemer / spark plug arc
Both electrodes get hot. If carbom forms on an electrode, the spark will jump to it and burn off the carbon, thus saving the metal.
Old 08-10-2005, 09:01:28 PM
Images: 6
-Mike
Mike:
As far as I'm concerned, the purpose of the two electrode plugs was to get a little more money from the customers. I don't think there's any advantage at all.
My opinion and Iim proud of it!
Take care - Elden
Bessemer Spark Plug Dallas Cox Oil Field Engines 3 07-14-2007 12:28:13 AM
NOS IHC spark plug - What does it fit? Chris Kirk Antique Gas Engine Discussion 3 08-21-2006 07:07:30 AM
Spark Plug ? Bill Schmidt Onan Generators 1 12-19-2004 12:02:15 PM
Which spark plug to use ?? Stevie Mote Antique Engine Archives 3 09-18-2003 05:50:34 PM
3 HP spark plug JD Thomas Winland Antique Engine Archives 5 06-03-2003 09:33:30 AM
